Originally Posted by Steve Hunt
That’s great info/summary. Mine is a 2000w Renogy inverter/charger. The spec sheet says 5-65 amps dc charge current. What is the 80% in your example? assumed max out of my batteries?
That is an interesting device. It seems more like a UPS that any RV-type device I have seen. It looks like it is what is called "Double Conversion". That basically means that AC input is converted to DC to charge a battery bank and that same battery is used for power into a DC-to-AC inverter. The other topology is called line-interactive. It doesn't have this strict (double conversion) separation between AC->DC and DC->AC .
This provides essentially total isolation between AC in and AC out. This is probably why you are not sure what is going on when you run the AC all night
https://www.eaton.com/us/en-us/produ...20and%20online.
It looks like you also have a DC-DC On-Board battery Charger with MPPT; is that correct? So you in addition to the unit above you connect direct to the battery as well for DC loads and Alternator/ Solar charging. That is a quiet capable setup in only two devices. I don't remember but doesn't that DC-DC also back charge to the start battery if it is low?
Yes this assumes Lithium and 80% effective depth of charge (90%->10%) vs. 50% for lead Acid.
It seems you could go either way (AC AirCon or DC AirCon). If you want the off-grid capability and what is probably quieter operation then I would go with the 12V AirCon. The double conversion (if true) essentially means you should have no startup overload issues.
Most of the 12V ACon units are less than 1000W and you can run any combination of shore power or generator and the Battery to AC Out conversion essentially isolates your AirCon from the course especially if you are using Lithium (super low impedance).
I don't have any first-hand experience with either of these devices just reading the manual and I'm an aerospace EE.
