Originally Posted by Steve Hunt
Just trying to uncover as much as possible...don't know what i don't know...I get tired of being disappointed by some functionality or lack of that is never told in spec sheets or general research but found out after you spend $thousands. I'm headed over to a distributor of it today, we'll see what I learn. Hopefully they have a functioning unit and a knowledgeable person. 22-28 db is highly unlikely, not to mention ambient db will be lucky to be 50ish
If you can find a working demo that is always best.
Please confirm whether or not this is the new variable frequency scroll type compressor.
Here is a video doing a review of various 12VDC AirCons. The US name-branded ones are double ($1600 to $4300) the Chinese offerings and they probably come from the same place.
Based on specs, this is going to be more efficient than the 120VAC units and with the inverter you have you will not be suffering an (12V to 120VAC conversion loss). So you could be up to 30% ahead of the game with the 12VDC units in terms of battery Amp-hr utilization efficiency. If the units have an actual "low" mode and can 1/2 the current draw then they are potentially even more efficient. You might consider taking a kilowatt meter to measure the AC draw (if that is the source) or a DC Current Amp. They are not too expensive if you don't have one.
So based on noise level and efficiency, the 12VDC unit (on paper) is a no-brainer.
The benefit of the Chinese units is that there are multiple vendors and even manufacturers of very similar if not the same basic unit. It would appear as if there was government support to produce a highly efficient unit that multiple manufacturers produce. In the US you would tend to have much more diversity until the marketplace gets very mature.
Of course, dropping $1300 for one warrants all due diligence.
