New to the forum. I bought an ambulance to convert to an RV. Just got it and getting started. Joined because I can't figure out a cable on the ambulance and I need some help. It is a Kussmaul auto disconnect but I can't find a cable with this connector any where. The cable serves to charge the batteries in the ambulance.
You will likely have to make up your own cable. Personally, I would strongly consider changing out the receptacle on the rig to a more common fitting, perhaps an RV 30 amp if the wiring can handle that much current.
I agree, I’d swap that out if possible, highly recommend as long as you’re at it to look at Smartplug 30 amp options, a much better, and safer, RV plug option. I swapped our plugs on our rig over and on the travel camper(since sold). They have full kits with the cord as well since your missing that, as well as several color options on the receptacle. Available on Amazon too
You might keep it, those outlets are pretty cool and common on emergency vehicles, when you start the engine, that center pin kicks out the plug automatically. Not something that an RV usually needs, but could be fun at the RV park.
