Old 07-08-2014, 11:15 PM   #1
Hi-Lift Jack Question
Can an SMB (home build) with stock bumpers be jacked up from the bumper? If not, from where would I jack it up, assuming that the stock type jack is not tall enough to lift it from a frame rail.
2horsegarage is offline   Reply With Quote
Old 07-09-2014, 08:02 AM   #2
Re: Hi-Lift Jack Question
Though some don't recommend it, I've jacked mine up from the axle or diff many times, but I don't leave it there long, and I do use jackstands to support it under the frame. If I had to do this on the road or trail, I would just be fast and careful I suppose.
Old 07-09-2014, 08:11 AM   #3
Hmmm. OK. I suppose that makes sense. I hate to travel with jackstands, but may have to until I have a way to use a hi-lift or something else.
Thanks.
Old 07-09-2014, 08:28 AM   #4
twogone's Avatar
Hi-Lifts make great trotline weights, or they can be used for ballast... much heavier than bilge water
'95 SMB E350 Quigley 7.3
https://www.taylorarts.com
Old 07-09-2014, 08:31 AM   #5
twogone's Avatar
I (and others on the forum) use the three ton combo jack /stand... but still need a bottlejack to get the first few inches in a fully-flattire situation. This thread discusses much of the issue
viewtopic.php?f=2&t=9556&hilit=jack+and+jackstand
Old 07-09-2014, 11:09 AM   #6
Tapatio's Avatar
My primary use is to raise a wheel if I get it high sided or stuck in sand/mud. Lift the wheel, put some rocks or whatever under the tire and then lower it. Try getting a bottle jack under the frame when you are buried up to your axles.
I also carry a 3-ton jack for other situations.
Callsign KK6GIY
Old 07-09-2014, 11:32 AM   #7
Agreed. I was basically talking about home or side of the road repairs. If I get buried offroad I'm screwed anyway. I have 2 bottle jacks but no winch and no hi lift. If I did a lot more offloading I would address the issue somehow. I like the Hi lift idea because you can store it outside bolted to a bumper or something. No other jacks with lift height enough for 4x4 vans store easily inside.
Old 07-09-2014, 12:37 PM   #8
Pschitt's Avatar
I use the same stuff than Tapatio.
Old 07-09-2014, 12:49 PM   #9
twogone's Avatar
I also refer to home/sideofroad. I haven't been buried up to the axle since, well, high school maybe. I try to stop diggin' when I feel 'er goin' down, but have no experience with western landscapes or rock crawling. I have, on the other hand, had experience with the asswhoopin' a Hi-Lift can issue.
Old 07-09-2014, 01:58 PM   #10
I was wonderin about that!
ClifFord
EliMakes
PigPen
velo47
