Old 01-28-2022, 04:13 PM   #1
Identify conversion
Hey Everybody,
Just picked up this 4 x 4 chassis to swap onto my 7.3 body/engine/frame.
Has kingpin Dana 60 front and full float Dana 60 rear.
I’m wondering if anybody can identify who the conversion was done by, it looks professional.
Cheers
CAD4852E-9FD2-4006-A99B-B700E1F8EF14.jpg   456AF70E-FC86-4448-B146-3BFBDD4A563A.jpg   73918CF5-46D1-4904-8750-1BCAB9F07026.jpg   04FFC70C-3834-42AB-AE14-EF02C89F7927.jpg   E83CB4B0-0191-4856-8B48-9648B6AAA9D6.jpg
Creative Plastic Research is offline   Reply With Quote
Old 01-28-2022, 05:09 PM   #2
That's a balljoint 60, not a kingpin. Also, blocks in the front suspension are a no-no. I haven't seen a van setup with the shackles at the front of the front springs in a long time, looks like stock F350 (<'98) design.
Old 01-28-2022, 09:02 PM   #3
Thanks for clarifying.
I’m deciding which direction to go. The UJoint kit seems like a good well tested platform.
Old 01-29-2022, 08:06 AM   #4
Also mounting leafs to the front of the crumple zone is a huge no-no as well, unless it’s reinforced. That van was most likely a home build, and it probably was not really drivable
Old 01-29-2022, 07:58 PM   #5
Gotcha, looked well done. At least I got a good set of axles (with 4.10s), transfer case, and some other misc.
Old 01-30-2022, 07:00 AM   #6
TomsBeast's Avatar
you're off to a good start!
Old 01-30-2022, 08:01 AM   #7
Get yourself a Ujoint diy kit and you should be in good shape.
2002 e350 window eb,
7.3
CCV high top
Conversion in process. Lol
Denver, CO
Old 02-03-2022, 01:45 PM   #8
The J is correct ball joint, not king pin. Blocks big no no. Shackle forward and the crash frame horns yikes. Shacles forward worst ride quality you can have.. Definitely good start just fix the mistakes it will be fine. I'd just go 4 link with 3.0 coil overs and use the rear fixed mounts as my lower arm mounts they look very well mounted.
Old 02-04-2022, 09:37 AM   #9
b. rock's Avatar
Looks not too far off from the Advanced conversion on my van. It's a mess, and getting cut off in the next couple of weeks (finally).
b. rock is offline   Reply With Quote
Old 02-04-2022, 09:46 AM   #10
B rock. What’s your plan next ?
