Originally Posted by 1der
dbhosttexas -
1. What type of roof do you have? Stock, Fixed , or PopTop?
2. What size rig do you have?
3. What is your location? (You can add location to your profile. if you like)
The pictured awning Vermonster posted will work if you have stock roof with a roof rack. No way a legless awning works with a pop top w/o very serious reinforcement where the mounting brackets are located.
I believe the max projection for Fiamma and most any other awning is 8 ft. Many are only 6 ft.
The Fiamma F-45S 300 (10 ft wide x 8 ft max projection) works well on both EB and RB vans.
Good questions.
1. Pop Top / Penthouse roof. Sorry I sort of assumed ALL Sportsmobiles are Penthouse tops, I know they aren't but it is kind of like Kleenex and facial tissues...
2. Regular length Econoline van.
3. Coastal Texas / Houston Metro. So it is freaking hot and I need shade when camping at the beach!
I would like something that at the least covers the passenger side of the van. I have a Joolca Double Ensuite with Awning kit, and that can slide in the corner behind the van easily.
I know awnings need to come down in high winds, but blowing rain events like a typical Texas spring rain and a sidewall should keep the rain, or blowing sand out of the van, or outdoor cooking space...
I CAN solve my issue with an EZ Up. I don't want too. They are too big, bulky, and flimsy construction wise to want to bother with.
For now I am using an Ozark Trail 12x12 Tarp Shelter with suction Cups to attach to the roof, and can shade wall, sort of the rig. It is definately a jerry rig but it works... Was just hoping for an easier to set up, more elegant solution.
