Old 07-31-2014, 03:09 PM   #1
Replacement Seat Belts
I've got an 07 E350 with a couple of seat belts that need attention. The long one that reaches the front bench seat doesn't retract, and then I've got another that has a hard time releasing at the buckle once snapped in place. I'm typically a Google Ninja but am having a hard time finding what I need. Any pointers would be greatly appreciated, thanks!
Archer is offline   Reply With Quote
Old 02-01-2017, 03:19 PM   #2
Okay Okay, so this is about 6 years after the fact, but I have the same issue and thought I'd post for anyone else who has the same.
I found seatbeltplanet.com Going to double check the SMB sizing tonight and order from them. (I'm looking to replace a seatbelt on the bench seat in the back.)
Sam C is offline   Reply With Quote
Old 02-01-2017, 06:25 PM   #3
Highly likely that Fam Vans in So Cal has them ( for $$$)
of course I gave away a complete set of mint rear belts when I sold my rear seats.......
Here you go...
https://www.cargovanparts.com/produc...-2007-row-5-lh
Old 02-01-2017, 07:33 PM   #4
I've got 2 captain chair style belts that I don't use in my 06 E350. If someone is interested I could pull them out.
gilp6636 is offline   Reply With Quote
Old 02-02-2017, 06:26 AM   #5
SMB has them too I've heard.
Old 03-11-2017, 01:31 AM   #6
Thanks for your help. I only needed lap belts and found that seatbeltplanet.com was selling them for about $30 a set. They are an exact match and I am real happy with them. Will get some pics up.
Old 03-11-2017, 04:39 AM   #7
tlg
tlg's Avatar
SMB North used belts made by Seatbelt Solutions out of Jupiter, FL. They manufacturer and sew belts that are then resold by other companies (Wesco Performance, etc). Ordered a custom belt to replace what was a dangerously long buckle end for the bench seat shoulder belt. Length really matters with that one. I'll do a separate thread with images of that fix and a four point solution to replace the two lap belts.
2014 Ford RB-50
Old 08-09-2018, 12:51 PM   #8
tlg: could you link to this thread? I'm replacing the rear passenger shoulder belt and would love to see how you did it.
ExitFetish is offline   Reply With Quote
Old 08-09-2018, 12:59 PM   #9
Also, that particular seatbelt (rear 3 point on passenger side) gets caught in the bench when we raise and lower it. It's tearing, which is why we're replacing it. Any tips to keep it from catching in the first place?
Old 08-09-2018, 01:21 PM   #10
tlg
tlg's Avatar
http://www.sportsmobileforum.com/for...eat-19312.html
You can adjust the angle of the rear shoulder belt. I found that helped with the belt not catching. Also found that rear shoulder belt attachment point was the source of a persistent mouse like squeak. Once tightened that went away.
2014 Ford RB-50
Agnes
ranchero
The YURT
MKRyan
