Most people place front windshield sunshade inside to help screen the sun- only issue with this is the reflection dramatically heats up the front windshield and produces extremely high temps - That heat doesn't go anywhere...stays inside.
I have about 2/3 of my pop-top covered by the solar panel & Thule box which do help keep temps down (mounted about 5" above the tops surface on an aluminess rack), but I also have a front windshield cover which mounts on the outside (it's black on one side & reflective silver on the other allowing me to use either) - When the van is in direct sun this outside cover alone keeps my inside temps down about 15 degrees compared to using a sunshade that sits inside the van.
We tried both scenarios one afternoon - about 2hrs with inside windshield shade & 2hrs with outside shade (BLACK SIDE FACING OUT). daytime temps were about 90 degrees, and we had the pop-top up with the 4 side windows unzipped about half way....15 degree difference measured by a thermometer approximately 2/3 of the way up and towards the back half of the van.
...This is just a pic of my front "outside" cover :
