Old 12-03-2021, 03:50 PM   #1
CDACamper's Avatar
Steel Braided Brake Lines
I've got a 2001 EB50 Quigly 4X4 with dana 60 rear axle and Kingpin Dana 60 front axle. I would like to upgrade the brake lines to steel braided from the original rubber lines. Does anyone have a source for brake lines that are already set up for length and proper fittings that would be plug and play?
______________________________
2001 E-350 V10 EB50 Penthouse
4.56 gears w/ARB Rear Locker
4X4 Quigley
Agile RIP
CDACamper is offline   Reply With Quote
Old 12-03-2021, 08:38 PM   #2
REF
REF's Avatar
Send a message via MSN to REF
You might have to find a nearby shop that can make you set.
Old 12-04-2021, 07:40 AM   #3
Check with Timberline Vans in Colorado
Old 12-04-2021, 08:43 AM   #4
I sourced mine from Fermin at Crown Performance. 760-599-0090
It's not quite plug and play and we did some back and forth. Length and fittings will vary between 4wd conversions, axles setups, and brake calipers.
https://www.crownperformance.com/
There's a few threads on this forum with more info and options.
2011 VW TDI Golf for hwy fun
Old 12-04-2021, 09:02 PM   #5
CDACamper's Avatar
Thanks for the leads!
4X4 Quigley
Agile RIP
Old 12-05-2021, 07:18 AM   #6
Just curious if anyone whose installed these have noticed any appreciable improvement over stock hard lines?
Old 12-05-2021, 10:08 AM   #7
I was wondering the same thing.
Old 12-05-2021, 11:29 AM   #8
CDACamper's Avatar
I have heard claims of improvement in the 'squishy feel' of the brakes on hard stops. I'm not expecting to see any improvement but they are the original rubber lines over 20 years old and on my list for preventative maintenance over the winter.
4X4 Quigley
Agile RIP
Old 12-05-2021, 11:45 AM   #9
The older the rubber brake lines are, the bigger the improvement when you replace them. You also get what you pay for, buy the highest quality lines you can afford. Cheap lines can feel squishy right out of the box. Because the length of the rubber part of the brake lines is fairly short you probably will see some, but not a huge improvement with new rubber lines. The braided steel ones are tougher, look cooler and will "feel" like new high quality lines much longer.
2002 e350 window eb,
7.3
CCV high top
Conversion in process. Lol
Denver, CO
