Re: CR Laurence window parts (AKA: repairing failed glue)
My replacement window is holding up fine but my other window was showing signs of glue failure but this one had stripped gears and I can't open it. I ran a bead of clear silicone all the way around to hold in the frame. Both of these windows are on the sunny side of the van so maybe a factor in the failures. It's not worth $500 to me to replace. So the remaining window (I have 3) is 10.5 years old now. I keep the gaskets clean & lubed so it doesn't stick and stress the glue on initial opening and I'm careful about over tightening. Just limping along here!
