10-14-2009, 12:46 PM
Re: Upgrade from Ford Factory Stereo; Speaker Location?
Wow I'm jealous. Good description. At $2,000 I think you can call yourself an audiophile now. That sounds like an amazing system you installed. Although it pains me just reading about the wiring you did. I hate running wire, nothing fun about it but worth it.
Working on Converting a 2014 Sienna AWD Limited for rock climbing and back country skiing
Previous Rig: 1996 EB Dodge with Contempo Top
01-22-2011, 07:07 PM
I just installed a Kenwood DNX7140 in my 2006 E-350 following Yubariver's instructions. Thought I would post some picture's to make it easier for the next person.
Tool required to remove stock radio. Amazon http://amzn.com/B0007TC9LW
In order to fit a double din stereo you will need to file down the top and bottom plastic lips. I used a dremel tool with a sand paper wheel. It should be completely flush when finished.
If you are installing a rear view camera and would like it to turn on automatically when you put the van in reverse splice into the positive wire that connects to the reverse bulb. The wiring harness is located on the driver side below the parking brake. The wire is black with a purple stripe.
A convenient place to put the GPS antenna. No drilling required.
Amazon sells a wiring harness adapter so you won't need to cut off the stock plug. http://amzn.com/B0007KK24M
To help secure the stereo I removed the rear support bracket from the stock stereo and attached it to the Kenwood unit. Helps keep everything secure on bouncy roads.
Handsfree microphone placement. Works great!
This device will bypass the lockout mechanism which prevents you from controlling certain functions while driving. http://amzn.com/B004803H2Q
Looks and sounds great!
Callsign KK6GIY
01-22-2011, 07:17 PM
Great write-up with pics.
01-22-2011, 09:50 PM
Great write up, but how does the passenger do Karaoke, or is only the driver allowed?
01-23-2011, 04:27 PM
On my lap of course, is there another way?
Callsign KK6GIY
06-01-2011, 05:17 PM
Location: Rolling Hills, Mammoth Mountain, Coeur d Alene Idaho
2008 xlt 6.0 psd
10-02-2011, 02:26 PM
Did you use the following dash install kit? (mentioned earlier in thread)
Head-Unit Dash Adapter (for fitting a Double-DIN head-unit into the 2006 Ford CORPORATE Double-DIN dash opening
.The ford opening is shorter and wider than standard): American International FM-K552, Amazon $13
The reviews say they are not worth the trouble, but your head unit does seem to have a little piece of trim around it? Came with it or.....?
Sportsmobile-less.
10-02-2011, 04:37 PM
Anzac - This is the double din dash kit I used. One warning, I don't think you can remove the stereo without removing the dash once it is installed. The side mounts have one-way clips that secure the stereo to the dash. There is a warning that comes with the instructions that is conveniently left out of the product description on Amazon...
http://www.amazon.com/gp/product/B0009JSDYC
Callsign KK6GIY
10-17-2011, 06:15 PM
Anzac, Tapatio,
You can remove the stereo with the double-din kit once installed, it's just not very fun. I was able to do it by working my hand and a very short phillips screwdriver up beside the unit, and removing the short flathead bolts that hold the plastic side-clips onto the unit itself. Once those are unscrewed, apply wiggling, jiggling, almost too-much force, swearing, leverage from a screwdriver, etc. and it should eventually come-out.
12-23-2011, 12:33 AM
#20
I noticed AI lists two wiring connectors for the 2002 van:
http://www.aius.net/proddetails2.asp?ID=162
http://www.aius.net/proddetails2.asp?ID=163
One is a white connector, the other is black.
Do you need both, or just one?
I haven't taken my stock head unit out yet. I just assumed it was one connector with power+speaker connectors.
Sportsmobile-less.
