Originally Posted by joefromsf
What's an EVTM? I mean other than a FLA (four letter acronym).
Originally Posted by shenrie
Electrical and Vacuum Troubleshooting Manual
EVTM. Acronym. Definition. EVTM. Electrical and Vacuum Troubleshooting Manual (Ford)
Correct!
That name or designation is particular to Ford vehicles, can be bought brand new from a dealer for upwards of $140 each. Also found on eBay for various prices and in various condition too. They're well worth their costs IMHO.
Originally Posted by tnmarm
So apparently, my drivers side kick panel loom, has TWO wires that are black with pink stripe. Tapped the other wire (which was deeper in the loom) and boom, thats the correct wire.
Now to find the "gray/black" vss wire they said should be in the same area.
One advantage to the EVTM's is they do show wire colors BUT also where any one wire terminates in a connector. If you can find the sought-after wire it can be double checked against the pin out location where it is inserted into a mating connector.
Another advantage is wire colors can/do change over time so the pin out is helpful there too. Also some wire colors change from one side of a connector to the other which is immensely helpful tracking some circuits.
One more bit---EVTM's tend to be particular to a given year, "close enough" is no longer good enough.
HTH
