Starcool 20 amp ac circuit has 4.5 volts with breaker throw (?)
Hi,
I’m troubleshooting electrical issues on our 92 Ford EB sportsmobile
We added two LiFePhosphate batteries and a dc-to-dc charger to intake power from the alternator and on board transformer that is plugged into shore power.
We protected against backflow with diodes and a marine switch (no input, alternator, shore power theough transformer).
The DC side-propane detector and lights are working fine. The fridge does not work, but it did with the lead acid house battery.
The AC side has some apparently dead breakers, which i’ll replace tomorrow. The 30 amp main is ok. Both 15 amp breakers (fridge, transformer and other power) aren’t passing current when on or off.
The starcool breaker passes 121.5 volts when on (same as the main breaker). But when it is off, it has 4.5 volts on it.
Is this normal? Do we have a leak from dc/house battery to the starcool (theoretically we shouldn’t)? Does van’s 12 volt system continuously power it?
Thanks for advice/ideas :-)
