Old 09-26-2017, 03:10 AM   #21
Shaggy's Avatar
Only pic I have of the airline and cap. Zoom in!
Sent from my SAMSUNG-SM-G890A using Tapatalk
2014 E350 EB Quigley 4X4 [HOONIVAN]
2014 FJ Cruiser
Shaggy is offline   Reply With Quote
Old 09-26-2017, 10:47 AM   #22
larrie's Avatar
Mine are in the running boards, yes I still have running boards.
Drivers side
[IMG][/IMG]
Passenger side
[IMG][/IMG]
Used rubber cane tips to keep the dust out of them.
Larrie
Old 09-26-2017, 01:25 PM   #23
Lenny's Avatar
Air connections
If at all possible and if you do a lot of beach or dusty trails I would suggest putting your air chucks anywhere inside the rig.
I have mine on the side of my drivers seat base. I plan on extending it to the passenger seat but for now all I have to do is pass the hose to the other side over the seat.
I was also lucky enough to mount my ARB compressor under the seat. Now everything is out of the elements.
Lenny is offline   Reply With Quote
Old 09-26-2017, 09:46 PM   #24
Front/rear bumper location for ARB dual compressor mounted on middle frame rail by driver side.
Tienckb is offline   Reply With Quote
Old 10-03-2017, 06:31 PM   #25
Originally Posted by Lenny View Post
If at all possible and if you do a lot of beach or dusty trails I would suggest putting your air chucks anywhere inside the rig...
I like my air chuck outside, so I use a rubber dust boot cover on it.
Old 10-04-2017, 01:43 PM   #26
MadScience's Avatar
I don't see that much mud, but dust and sand are almost constant where I end up camping. I wondered about issues my external quick connect, but so far, the compressed air just ends up cleaning it out as I make the connection. I generally leave my air horn plugged into the connection these days. -- I wanted to make that easy to disconnect in case an officer took issue with it.
My connection is centered on the driver side by the frame rail. I do want to add another one on the passenger side.
Old 10-04-2017, 03:00 PM   #27
TomsBeast's Avatar
Originally Posted by Vegasrandall View Post
Has anyone used the york AC compressor conversion for onboard air?
My engine compartment is really cramped, I have no idea where you'd put a second AC compressor
Old 10-04-2017, 03:19 PM   #28
REDOVAL's Avatar
here is a York 210 setup i have been working on...needs an actual bracket but you get the idea
Scott
20160629_170638.jpg   20160605_175602.jpg   20160710_171901.jpg   20160710_175548.jpg
2002 Ford E350 V10 Traveler
Vantage Optics Headlights
www.VantageOptics.com
Old 10-04-2017, 03:32 PM   #29
Scott
From what I've read, be sure to mount the suction port on top due to an oil return line. No firsthand knowledge if this is accurate or not. I still have my York compressor sitting on a garage shelf instead of mounted in my Bronco where it's supposed to be. Been on a garage shelf for years...
Old 10-10-2017, 02:58 PM   #30
I put mine out back and was really careful to always cover it. Still got jammed with sand and dirt to where I couldn't use it one time. I'm going to just run them to the interior to keep them clean.
jblaze5779 is offline   Reply With Quote
