Old 03-11-2013, 03:21 PM   #101
spurious's Avatar
Re: 2000 4x4 Ford Van Build
The wheels that are on the van in the last photos are factory 3140 alloys...no one is supposed to notice the dodge caps I have been trying some new wheels out. And will post them next.
The rack is home built....but if you research ujoint's racks that is a close solution to building your own. High quality and affordable. Good luck
spurious is offline   Reply With Quote
Old 03-11-2013, 03:26 PM   #102
spurious's Avatar
2008 Factory Dodge 17x8 aluminum wheels.
Old 04-28-2013, 02:00 PM   #103
Hi great build up
can you tell me where you got the frame for the folding bed?
rockhead is offline   Reply With Quote
Old 04-28-2013, 02:42 PM   #104
spurious's Avatar
Thank you I got the frame out of a conversion van at a pick a part.... Good luck
Old 04-28-2013, 07:52 PM   #105
Wheels look great!
Old 06-15-2013, 06:44 PM   #106
Congrats on the new Van... Lots of questions:
Lift:
Is that a two wheel drive with just a lift?
Which lift did you get Performance Suspension System or Ultimate Suspension System?
Did you do the lift yourself?
Did you raise the rear of the Van?
Fiberine Top on Your old Van:
Did you have Fiberine install your 24" Bubble top?
Did you insulate the top, if so how did you do it?
What are your plans for your new Van?
Thanks for sharing
jnbthomas is offline   Reply With Quote
Old 06-15-2013, 09:33 PM   #107
spurious's Avatar
The new van has a action van 4" lift front and rear and it is still 2wd. If I were to do it again I would do the ujoint conversion. I installed it myself and it was as much labor as a partial 4wd conversion.
The fiberine top was also self installed on my previous van, it is real basic sawzall to cut the hole and then bolted and screwed. I used the reverse lip so no exterior trim was needed. I purchased the non insulated and added carpet to the inside for sound and insulation.
My plans are pretty minimal for interior on my current , I have double benches for the back that fold into a bed. They are removable and I use those when camping and traveling. I've put so far just over 60,000 miles in the past year and is probably my favorite van that I've owned.
Hope that answers some questions, thanks
Old 07-14-2013, 08:01 PM   #108
Mr.Spurious Your work is VANTASTIC!!!!! I have a 2001 E150 and would like to add a Eurovan pop top as you did, could you please tell what year you used? Thank you so much. Tim
tsolis is offline   Reply With Quote
Old 11-18-2013, 04:36 PM   #109
Last I contacted the Ujoint folks they no longer made racks, and I've never welded. If you need to get rid of that one I'm in Denver...Beautiful work, by the way.
contender is offline   Reply With Quote
Old 11-18-2013, 08:22 PM   #110
Any issues with the sliding door and 285/75/16 wheel-tire combos? What bumpers are those? Great job overall.
01' E350 7.3 4x4 SMB PH, VS interior
16' Jeep Rubicon
16' Adventure Trailer Chaser
94' LR Discovery - built
KF7KOY
01E350AZ is offline   Reply With Quote
