Old 03-24-2010, 09:43 AM   #11
GreyDawg's Avatar
Re: custom Penthouse ideas
Originally Posted by AndrewST
JT,
Regarding the lifting system, I plan to do a cisor mecanism with gas struts that I have seen in european rooftents that I sold. Am currently looking with that manufaturer for the side walls also.
If I do a decent work, maybe a few more could be build.
Andrew --
definitely take a look at a GTRV or a PleasureWay Traverse if you have the chance -- the lifting mechanism is driven by gas struts, and might give you a few more ideas.
You can contact the sales rep for GTRV (used to be Mike and Julia Reed) and ask them if there are GTRV owners of T-tops and V-tops in the Portland area who have agreed to show their vehicles.
This sounds very interesting...
GreyDawg
GreyDawg is offline   Reply With Quote
Old 03-24-2010, 08:53 PM   #12
AndrewST's Avatar
JT,
I have asked a fiberglass company in Portland.
They use a single use mold or permanent mold..
Two options, Fiberglass with foam strips to reinforce or sandwich with foam core.
The top is not that expensive, the mold is...
You got it,4 shocks for the weight and the cisors to guide the roof.
Let me go ahead on the project and then will be able to give more details currently I am working on the floor and side pannels.
GreyDawg,
Will try to see one, thanks.
Old 03-25-2010, 02:42 AM   #13
A swiss guy might want one...
Now I wonder who that might be
+ 2001 Saab 9-5 Aero Hirsch
+ fixed house (Argh)
Old 03-29-2010, 07:11 PM   #14
If you just want a pop top big enough for a bed I am currently prototyping a top that will fit on the roof of any van as a complete kit. It uses the top half of my top bunks (www.topbunkusa.com) and will set on the roof of any van watch my web site in the next few weeks I will have some pictures posted of a chevy van with this top.
Derek
https://WWW.COLORADOCAMPERVAN.COM
00 PSD EB Quigly being converted to a Colorado Camper Van top
73 ford e100 soon to be 4wd with a 4bt
72 bronco aod injected 351 4 linked arb f/r 38in swampers
72 bronco 302 c4 soon to be 4bt w/ 5speed 4 inch lift 33 swampers
81 cj 7 in pieces at the moment injected twin turbo 401
ktm 525 exc, 620sx,
62 caddy convertible waiting for me to install 2007 northstar
dsw4x4 is offline   Reply With Quote
Old 04-07-2010, 10:28 AM   #15
GreyDawg's Avatar
Hang on....Andrew has a Ford van. Saabman has a Chevy van. So a mold that is made for the Ford van wouldn't fit the Chevy van, right? Doesn't SMB have different molds for Ford vs Chevy?
GreyDawg
Old 04-07-2010, 01:36 PM   #16
bettyford's Avatar
I installed my top incase you havent seen it go to the "Betty2" post in this thread and you can check it out.
Ron
Going where most dont
"one day at a time"
Old 04-07-2010, 04:34 PM   #17
Not Sure, I gathered they are the same mould and only detailing differs...
Can anyone confirm?
Old 04-07-2010, 05:16 PM   #18
Can anyone confirm?
That's what I thought. Some differences in trimming to fit the contour of the different vans.
Old 05-18-2010, 09:48 PM   #19
jtolittle's Avatar
Hello,
So my top is almost finished. I am just fairing a little more and getting ready for the paint.
I am planning on having 2 scissors mechanism on each side to lift the roof about 30-35" high. the top is about 100 lbs right now. If I mount a rack or bikes or kayaks, it will be much heavier, so much harder to raise. I would like to mount some springs in between the scissors to help bring the roof up (and keep it up!!). 4 springs in total. Let's say to help raise 100 lbs of roof + 150 lbs of "stuff". So 250 lbs divided by 4 springs is about 60 lbs per spring. Very reasonable. BUT!!!! If I have 250 lbs of springs load to help me raise the roof....what if I want to lower the roof and there is no "stuff" on top???? Only the 100 lbs roof...Do I have to pull 150 lbs down??? That's almost my weight..do I have to suspend myself to lower it? a bit of workout every morning before I change campsite!!
do you think it works like this or springs have their own special magic?
thanks
JT
PS : the system would be very similar to an older VW roof I think. I have seen a picture on Spurious van with that mechanism...
jtolittle is offline   Reply With Quote
Old 05-20-2010, 08:59 PM   #20
Originally Posted by jtolittle
..Do I have to pull 150 lbs down??? That's almost my weight..do I have to suspend myself to lower it? ...
eat a couple sammich's...that should help...
gravity will be helping you..so it shouldnt seem that bad..and it depends on where in the pivot they are attached...think the cam's on a compund bow (bow and arrow)..
8 lugs and glow plugs..
85 E250 Turbo 6.9 vegiburner
92 explorer (well the vin tag and body skins are anyway)
09 jeep wrangler unlimted...for walmart wheelin!!
nothing scares my wife like my boredom and a welder!!
wanderer351 is offline   Reply With Quote
