01-16-2024, 03:25 PM
Intermotive Fast Idle iii for E Series
I found this overstock for $90 vs $200+ from distributer. I got one, there's one left.
https://skycraftsurplus.com/products...ystem-iii.html
2009 E250 RB 5.4L "SilVan"
01-16-2024, 03:52 PM
Good find, and a great deal...but does specify for 2009+ model E-350's.
My manual 'high idle' comes in handy for a variety of uses, more so when shore power isn't available & little to no sun to benefit solar (running the van for a little while just to dump some amp's back into the battery bank, occasionally starting the van when I intend to use the microwave for more than 4 or 5 minutes, letting the van heat up quicker in cold weather, etc). So convenient to accomplish this without having to be in the drivers seat w/foot on the pedal the entire time.
01-17-2024, 01:53 PM
I plan to use it for recharging in camp instead of a generator. Don't have solar.
01-17-2024, 02:11 PM
I installed an Intermotive Fast Idle on my Transit. Works as advertised, easy install.
01-17-2024, 05:06 PM
Yes, thanks for posting that. I have been thinking about fast idle controllers but there are very few available for the E250 and they are expensive and quite involved to install. When I read your posting, I searched for INtermotive and found the surplus units. Score!
01-18-2024, 03:44 AM
We have the oem equivalent. Besides the reasons TwoXentrix mentioned I love that it bumps up automatically when it sees a heavy draw like when we’re using our winch. It’s definitely nice for cold starts too, not that the 7.3 ever really warms up without driving.
01-18-2024, 10:32 AM
Is this substantially different than wiring up SEIC (Stationary Elevated Idle Control) per the body builder's layout book? Or just a pre-packaged way to do the same thing?
I have SEIC wired up to one of my upfitter switches. It was "free" with a relay and resistor I already had sitting around. I keep meaning to replace the resistor with a potentiometer so I can adjust the idle speed, but there really hasn't been a need.
01-19-2024, 10:53 AM
Yes, this one plugs into the diagnostic port and works by magic. I didn't want to diy it or try to find the right wires. I only need to find the port and a ground.
02-03-2024, 10:02 PM
Sorry no pics... I got the Intermotive fast idle installed today. The biggest "win" for the project was I used a toggle switch that I bought in 1967 for a 6th grade science fair project! That makes it 56 years old. I have re-used it over the years and the leads are shorter than when new, but I was able to crimp on some butt splices.
Anyways, the Intermotive fast idle works as advertised - flip the switch and it ups the idle to 1500 rpm. The OBDII port is still available, since the wiring harness has a t-connector. I did test the house battery charging before installation. The 200 amp-hr battery was at 90% and charged at about 20 amps at 650 rpm and same amps at 1500 rpm. I still need to test it with the house battery discharged deeper.
