Here are some links that might help.
If the ICP doesn't reach >500psi, the injectors won't fire.
We were driving on I-80 and suddenly lost all engine power (like the engine turned off).
We rolled to a stop and checked Utube for help.
We had recently installed a Edge CTS2 (
now a CTS3) to replace the scanguage and that allowed us to DIY that the hi-pressure oil system was broken.
Got towed home and spent some money to fix the issue.
What was on the repair list for the "bulletproofing?" STC fitting? dummy plugs?
https://www.powerstroke.org/threads/...dition.142850/
6.0L Power Stroke Troubleshooting Guide & Diagnostic Procedures
Usually, in order for the engine to start, with your scan tool, you look for (cranking values):
cam/crank sync (sync=1)
FICM sync (the FICM is the Fuel Injection Control Module) (sync=1)
Commanded fuel pulse width, FPW (to ensure that the fueling command is given)
ICP pressure of 500 psig minimum
Cranking speed of 150 rpm minimum (PC/ED says 100 rpm, but functionally it is 150)
Acceptable system voltage (typically over 10.5 volts)
FICM Main power (MPower) of 46-49 volts
FICM logic power (LPower) voltage of over 10.5 volts, and
v-reference voltage (5 volts +/- .5)
