Old 11-04-2012, 09:47 PM   #1
4x4kayaker's Avatar
12 volt toaster?
Does anyone have a 12v toaster? I did a quick google search and couldn/t find one. Maybe they pull too many watts? I've been using a cheap on top of the gas cook stove toaster but I'd like a plug in 12volt if they make one to free up my stove top.
4x4kayaker is offline   Reply With Quote
Old 11-04-2012, 09:50 PM   #2
larrie's Avatar
12 volt toaster?
Where did you find the gas cooktop toaster? Have been looking for one with no success.
Larrie
Old 11-04-2012, 10:45 PM   #3
12 volt toaster?
I'm pretty sure Coleman sells one of those at Walmart type stores. It's just a rack basically I think.
Old 11-04-2012, 11:45 PM   #4
Re: 12 volt toaster?
http://www.shopwiki.com/l/Stovetop-Toaster
Old 11-05-2012, 07:39 AM   #5
I have a toaster, it's 110v, but only 1300w... relatively lightweight.
There are a smattering of toasters and ovens available for big rig trucks in 12v, IIRC.
Old 11-05-2012, 05:41 PM   #6
larrie's Avatar
12 volt toaster?
Here are a couple of links to 12 toasters. Have no idea how well they work.
http://m.bing.com/search/?q=12+volt+toa ... s&MID=2500
Larrie
Old 11-15-2012, 09:29 AM   #7
TomsBeast's Avatar
Speaking of 12v appliances.... the larger interstate truck stops typically have a section in the store that caters to long-haul truckers, stocked with all sorts of 12v appliances.
Old 12-03-2012, 09:02 PM   #8
KANZ's Avatar
Here is a cheap and unassuming toaster for the gas stove top. Compared to other versions this one works really well, others just dry the bread. http://www.rvplus.com/camp-a-toaster...FSFyQgodNEsA1Q
kanzoutdoors.com
KANZ is offline   Reply With Quote
Old 12-17-2012, 05:39 PM   #9
4x4kayaker's Avatar
I've been using this cheap over the gas range toaster:
http://www.campmor.com/outdoor/gear/Product___23102
But I want to get a 12vt reasonably priced plug in toaster that works well. Anyone out there use a 12 volt toaster that does not coast over a hundred bucks
Old 12-17-2012, 05:46 PM   #10
Keep in mind that 12-v appliances require heavy-gauge wiring. You may be better off using an inverter with regular appliances instead, which allows you to keep the large-wires to a minimum (batt-->inverter) instead of running welding lead through the van to your toaster.
