Old 08-18-2008, 06:47 PM   #11
Scatter,
I have a factory wiring manual for an '05. Just spent 45 minutes trying to find the buzzer - no luck! Sorry.
Finally found the "Key in Switch" connector, but the circuit just goes into the instrument cluster and disappears. Maybe the chime is in the instrument cluster itself. It seems to indicate the seat belt chime is in the instrument cluster.
Old 08-18-2008, 08:47 PM   #12
CJ
Send a message via Yahoo to CJ
Can't confirm, but I did hear overhear some one with an SMB say that there is a coded squence that can be peforme to stop it for ever. Might need to call the factory.........FORD that is.
CJ
CJ is offline   Reply With Quote
Old 08-20-2008, 08:06 AM   #13
Yes there is some on/off wait, flash sequence. Of course once used it's forgotten. I even forgot that I had a seatbelt buzzer. It might be on here some where too, have you searched yet?
Old 08-20-2008, 07:54 PM   #14
scatter's Avatar
Yeah, I've used the manual to shut off the seatbelt buzzer, but the chime for leaving the key in the ignition is still there. That's the sucker I'm trying to find. When I'm done with a major honey-do here, I'll check into it once again.
Scatter
2007 RB50, 6.0
K1WGB
Old 08-20-2008, 08:27 PM   #15
I wouldn't be suprised if it's part of a larger component. The days of being able to pull just the buzzer are long gone. Good luck though!
Old 08-22-2008, 01:12 AM   #16
NRL
NRL's Avatar
Send a message via Yahoo to NRL
How about the stereo speakers? Might be easy to disconnect all of them or cover them with blue tape and see.. Hopefully it's not built into the ECU.
95 FJ80 ARB/Kaymar/Emu
2005 AMG CL65 691hp 875tq
NRL is offline   Reply With Quote
Old 08-31-2008, 12:22 PM   #17
Jeffrey's Avatar
The Ford manual is WRONG. I performed the routine to turn off the belt chime three times and it never worked. It's not confusing. Nine insertions of the buckle and then one more to finish. Don't work!
NRL said the buzzer was "a grey box with a plug on the bottom. Just pull it out." Sorry there is NO grey box anywhere. What year is your van? How about a pic?
I'm so tired of this crap.
Old 08-31-2008, 03:47 PM   #18
scatter's Avatar
I've used the Ford manual to turn off the seat belt chime, and it worked fine. This did nothing for the key left in the ignition chime though That sucker has to be hard wired into a super hidden black box.
The search continues....
Scatter
2007 RB50, 6.0
K1WGB
Old 09-02-2008, 09:23 AM   #19
oldbonesclimber's Avatar
Key-in Chime
Scatter,
The easiest way to stop the Key-In Chime is a Black w/ Pink wire under the lockset. Just remove the lower cover for the steering column. Unscrew the tilt handle and 3 screws. You can also locate it at the connector just to the right of thr steering column behind the Knee Bolster it only grounds out so it doesn't seem to affect any other systems. I snipped mine and all is well. Even Better as the Chime has stopped. I'm now in the process of installing the Ford Remote Start system. I may have to find a way around the Key-In Sensor another way but no problems as yet.
I have a 2007 E-Series Wiring Manual and it made it much easier.
Oldbonesclimber.
2007 RB50 PSD
oldbonesclimber is offline   Reply With Quote
Old 09-02-2008, 03:20 PM   #20
scatter's Avatar
oldbonesclimber - I saw that wire on page 60-1 of my wiring diagram, but also noticed that it goes to the dreaded (gasp) PCM. There's not many things that my feeble old mind remembers, but I do remember messing with the PCM on my old van and having the pleasure of purchasing and installing a new one.
But, it's nice to see someone else that is willing to grab the bull by the horns, er the wire by the snippers, and have at it. Well, seeing as how you did it (you did do it didn't you, not just said you did?) I reached under the dash, while my key was in the ignition chimeing away, and did the deed. After one last bong, blessed silence!!!! Of course, after the sparks died down, the van won't start, but at least it's quiet with the key hanging there and the door open while I work on the repairs....
JUST KIDDING, it's GREAT!!!
Thanks for taking the time to look it up and post the fix.
Scatter
2007 RB50, 6.0
K1WGB
Rattle-n-hum
dar636
The Hulk
Hulk
