02-09-2024, 11:11 PM
Secured Lockbox: Recommend? Attachment?
Hello SMB-ers
I have a 2001 Ford E-250 RB50.
Assuming expectations of break-ins, I am seeking recommendations from this community best way of securing stowing: - wallet, cash, passport, papers
- Responsible handling to keep out of harm's way
- (optional) 13-inch macbook
Recommendations... - Make/model of Lockbox?
- Location to attach Lockbox?
Thank you
Jeff in Seattle
02-10-2024, 07:01 AM
What does your interior layout look like, is it the typical 50?
Are you looking for a bolt on solution or willing to do some fabrication? Sounds like bolt-on but just checking.
You say RB50 but your signature says EB ... ????
02-10-2024, 07:31 AM
Appreciate your response. Thank you for pointing out my signature.
- interior layout is an RB50, a typical 50.
- Bolt would be preferred but willing to do some fabrication
I did some homework and came across two sites
Jeff in Seattle
02-10-2024, 08:07 AM
Hiding things in plain sight is going to be just as effective, if not moreso, than something like one of those car safes that bolts down in a common location. Thieves are pretty good at what they do, they know the areas to check and the tools to use to be in and gone pretty quick.
A low cost, low effort, and surprisingly effective security measure is to use one of the fake battery shells they sell on Ebay and put your stuff in there. Use a regular battery hold down and its moderately secured to the piont of needing hand tools to get it out.
https://www.ebay.com/itm/36412420487...ntid=622851436
02-10-2024, 08:13 AM
In the typical 50 I like the cubbies below the closet spaces on the driver side. Kind of depends on what convenience one wants balanced with "harder to find".
I think a cool spot, if not occupied by a table top is the underside of the couch seat. Good for wallet and lighter items, bit more difficult for a laptop. Another for attaching a box is right behind the driver seat on the vertical wall but this is far more visible.
So, picking the potential spot, or more likely spots, will then dictate dimensions. I have played w the idea of the hotel room type safe but each time I nix the idea due to size and the clear space needed to open the door. I revert to hiding vs locking since there are so many spots to hide stuff.
Would a locking box in the cubbies work for you?
02-10-2024, 10:20 AM
fake battery shells
I like this idea!
Since under the hood there is only one battery hold down, would I need to add another?
Has anyone else in this thread tried this approach?
Thank you
Jeff in Seattle
02-10-2024, 10:23 AM
I have considered under the sink.
I have considered that as well, yet I place my cooler there. Worth considering again.
I will
Thank you
Jeff in Seattle
02-10-2024, 01:30 PM
I found a lockbox made for a Jeep that fits nicely under the seat. A couple of pieces of flat bar steel welded to the seat frame and the box made for a easy install.
02-10-2024, 02:47 PM
Do you have more details?
Thank you
Jeff in Seattle
02-10-2024, 07:24 PM
PM sent……..
