Old 12-08-2015, 12:55 PM   #1
MrHenrietta's Avatar
Advanced 4x4 "DeQuiglification"
So out of curiosity I contacted Advanced 4x4 here in SLC and asked what it would cost to "DeQuiglify" my van and upgrade to a leaf spring front end and 6 in lift. While I'm not super mechanically inclined, his estimate seemed a little low to me.. Am I missing something?
Randy's response:
"You will need to do the front and rear. Also, adding extra lift will require a little more as well. The total cost (without looking at the vehicle) will be approximately $2800.00"
2003 7.3 UJOINT 4x4 SMB
MrHenrietta is offline   Reply With Quote
Old 12-08-2015, 01:52 PM   #2
Yeah, that is really low and I wonder if something did not get communicated correctly.
eddyturn is online now   Reply With Quote
Old 12-08-2015, 03:22 PM   #3
If you think about it, they will use the existing axles. It's essentially remove the coils and add the leafs. Could be a valid price.
Old 12-08-2015, 03:43 PM   #4
Anyone know what the downsides and upsides would be in doing this? Would it permanently fix the threat of "death wobble" given all other front end components are in good shape?
Old 12-08-2015, 03:46 PM   #5
mikracer's Avatar
What would they have to do to the rear?
Old 12-08-2015, 03:49 PM   #6
Either type can have wobble for any number of reasons.
Old 12-08-2015, 04:14 PM   #7
rallypanam's Avatar
I'm not sure what the advantage would be.. I'd just fix your Quigley and save a bunch of money.
Old 12-08-2015, 04:38 PM   #8
New springs in the rear.
Old 12-08-2015, 04:49 PM   #9
Probably referring to any adjustment in height using blocks with changing the front.
Old 12-08-2015, 05:04 PM   #10
mikracer's Avatar
Seems that aftermarket leaf springs are in the $1,000 and up range. If they put new leafs on both ends, that would eat up a lot of that estimate. Then the cost for the front hangers, mods to the existing front axle, and new shocks since ride height would be changed, seems the estimate is low. If they only put a block in the rear and don't change out the shocks, then it seems it could be doable.
