Well -- I like math a lot, so I made a spreadsheet to help with perfecting the ratio adjustment. All you need to input is the modified/stock gear ratio, tire size and number of tone ring teeth and the spreadsheet will output your adjustment ratio.
Link to copy the google sheet is here:
https://docs.google.com/spreadsheets...lSaIN0h8Q/copy
For example -- my adjustment factor is .158 -- which accounts for a lower gear ratio (4.30 vs 3.55), bigger tires (35'' vs 30.5'') and the increase in the number of pulses per output shaft revolution (3 on the 2WD 4R100 and 18 on the 4WD 4R100). This is a very low adjustment factor!
As a note -- the
Abbott ERA Calibration Table online only goes down to .330 for fine adjustments, but it appears that if you you tell them the exact number you need they can provide something within .1%.
I'm going to try this unit which looks affordable and well made...
Universal Speedometer Corrector
Unless of course I can find that Abbott ERA I bought like six months ago that I probably accidently threw out with the trash...
EDIT:
I assume the 2WD tranny has a 3 tooth tone ring since that was noted previously on this thread. From the looks of it online the 4R100 2WD Tranny also has a 18 tooth tone ring... so you may just really need to adjust for tire size and gear ratio... wish I pulled the tailhousing off my 2WD unit before selling it, oh well.
The ATSG says the 4WD version doesn't even have a tone ring, which is wrong!
Anyways -- you can easily manipulate that parameter in the spreadsheet -- so have fun with it if you want!!
EDIT 2:
Well that was a rabbit hole -- seems the van 4R100 is actually a gear driven output speed sensor -- perhaps that's where it gets the 3 pulses per rotation. No idea how it works -- but I assume it is generating AC voltage/hertz based on rotation -- so given that the Abbott ERA works -- it must be somewhat compatible with what the computer wants.
Another reason I want to add an oscilloscope to the toolbox someday.
Vehicles are funny sometimes -- the more you learn, the less you know.
