Originally Posted by mk216v
Yes, the RSC brake upgrade at $2700 extra above the axle price. Why I mentioned that with MG's kit and the '13+ axles, you essentially get "free" 14.3" brakes. Also, IIRC it's the '16+ axles which have even larger knuckles and other goodies too.
I do not think the 16+ have larger knuckles. I have a 2016 axle and I was fiddling with the idea of replacing the passenger side knuckle since it had minor damage to the hub seal surface. The part number is: DC3Z-3130-A and it is listed as compatible for 2013-2016. Maybe it is bigger and just backwards compatible?
https://www.tascaparts.com/oem-parts...3z3130a?c=az0x
On the recommendation of a tech, I ended up making it work with a bit of filing and some RTV on the hub seal. Guess it is real common on the Dana 60.
What other goodies come with 16+?
