Old 01-14-2021, 07:04 PM   #441
Originally Posted by amamdani View Post
Thank you HintonbrosRV.
I will order both those products tomorrow.
What rear shocks do you use?
Brake lines, rear?
Rear Shocks Fox 2.0 P/N 985-24-061 (2ea). This what I used. The bottom attachment was a little too wide, so I trimmed them to fit. Maybe they fit w/ Sterling Axle, I dunno. I have a factory Dana 60 w/ Trac-Lok Positraction.
I didn't need to change rear brake lines. I did adjust brake line bracket on LH side of the frame above rear axle to allow some more length at full travel.
HintonbrosRV is offline   Reply With Quote
Old 01-15-2021, 12:45 PM   #442
Originally Posted by HintonbrosRV View Post
In rear, I used the Sky Offroad Design's 4.5" rear shackle flip & 1" extended Shackles (78-97 Truck/Bronco). Several guys have used this w/ good results. Also used 6 deg pinion shims from WFO to help w/ pinion angle. With cc880s springs in front, this brought me mostly level. Adding a leaf will get you a couple more inches.
I like this approach. So you left the spring perches at 0 degrees and used the shims to adjust the angle instead. That correct?
2002 E-350 7.3L PSD Sportsmobile Poptop
1992 E-150 4.9L Sportsmobile [sold]
Turbo is offline   Reply With Quote
Old 01-15-2021, 12:57 PM   #443
Wow so much info.
Hey all,
Let me first off say there is a wealth of info here. I've been reading now for what seems like ages.
Now to the task at hand. It appears that I have a bit of a rarity when it comes to builds. Mine is a 1992 E350 clubwagon with an EFI 460 and E40D. Now I have talked to Michael about the trans and converting it to 4x and have come to the conclusion that the easiest option for the t-case is to rock a divorced NP205. Helps with driveshaft angles, is a drop in with a new x-member and no messing around with the stock trans.
Now the question begs...
I have access to a ton of f250's and 350's of a broad range of years. Mostly rolling chassis. With the 1992 is there anything anyone can think of that might be problematic with an MG kit? And if you were selecting the gold standard donor truck, what would it be.
6 - 8" height is goal overall if that makes a difference in the donor truck.
Seeing as this is Just in the infancy stage, I want to catch all the minute details and idiosyncrasies as soon as possible before pissing away cash.
CHEMMINS is offline   Reply With Quote
Old 01-15-2021, 12:57 PM   #444
Yeah. Since I didn't change rear axle I didn't adjust pinion angle via perches. Honestly, I didn't actually ever measure my pinion angle as I should have. I had seen another website or on facebook that guys used the 6 deg shims (which is the largest I could find) and seemed to have good results (no vibes, etc). I've got about 4000 miles now since modification and am very happy with it so far.
Old 01-15-2021, 01:41 PM   #445
Originally Posted by CHEMMINS View Post
Hey all,
I wouldn't expect any issues w/ MG kit. Buy one if you haven't already. Donor truck ideally would be the newest axles [2013 to 2016] with lowest miles that you can afford, with a preferred gear ratio that you want. Searching this thread along with data provided with MG kit will likely answer most questions.
Get er done.
Old 01-27-2021, 08:59 AM   #446
So this is going to sound like a silly question..... I know most people shoot for a 4-6" lift with this kit, but how easy would it be to get 3" or less? Could someone run OEM springs and get a lower lift? I know most people use the CC880(s) and blocks or customer leafs in the rear.
spazegun2213 is offline   Reply With Quote
Old 01-27-2021, 09:03 AM   #447
b. rock's Avatar
You'll run into issues with constantly hitting bump stops, or your oil pan. The engine - axle clearance on the vans is what drives the lift height.
b. rock is offline   Reply With Quote
Old 01-27-2021, 09:06 AM   #448
I figured, given you need to trim the cross member as well. But, the quigley and other older 4x4 conversions seem to have a much lower lift?
Old 01-27-2021, 09:12 AM   #449
b. rock's Avatar
They did, and they rode on those bump stops a lot. That's partly why the RIP kit from Agile is so popular - it increases the lift a bit so you actually use get to use your springs on the up travel.
A TTB conversion can keep a lower lift because it's a hybrid between IFS and solid axle. If you want a lower lift but 4x4 that could be your route, although I'm not sure who is doing those anymore.
Old 01-27-2021, 10:04 AM   #450
Good to know! Thanks for the info.
As for a TTB conversion, I'm sure that is a LOT more expensive and complicated for what its worth.
