Old 09-01-2020, 12:34 PM   #21
Originally Posted by mk216v View Post
Tell us more...why no mechanical (ie helical/gear LSD) in front?
The biggest problem with a full mechanical locker (or tight limited slip) in the front is that the vehicle will pull forward when turning which makes tight turns very hard to do and puts a lot of strain the on drivetrain. The inside front tire really needs to be able to go slower than the outside tire to turn. Switchbacks would be a PITA.
RememberTheFallen is offline   Reply With Quote
Old 09-01-2020, 09:31 PM   #22
Originally Posted by arctictraveller View Post
Another data point: I've only got about 100 miles on my new Trutrac, but I've discovered that it chatters on hard turns, enough to rattle loose stuff.
Update: I talked to Eaton customer service today and explained my issue. The tech's first question was What kind of oil are you running? I said the builder filled it with 80/140 semi synthetic. He said "that's your problem, switch to a petroleum based GL5 oil and you will be fine. I asked about waiting until the 500 mile oil change and he said I could be doing damage and causing galling.
I'm really not impressed with Randy's ring and pinion................again.
Old 09-01-2020, 10:48 PM   #23
I'm happy with my front and rear trutracs. I've been able to run trails with my jeep club using them. If I'm going to climb something where I know the van will lift a wheel, I'll give it a little left-foot braking to bind 'em up a little and up it goes. It works well for me.
Trevor is offline   Reply With Quote
Old 09-03-2020, 02:46 PM   #24
mk216v's Avatar
Yikes! How can they not know this? That's all they do is gear work.
A vehicle’s worth is not what you put into it, but what it put into you.
2019 F350 SuperCrew flatbed composite camper
2018 Transit 130WB MR EcoBoost (SOLD)
2010 E350 RB V10 Cargo "unicorn" (SOLD)
2007 E350 4x4 "VANdiana Jones"(SOLD)
mk216v is offline   Reply With Quote
Old 09-16-2020, 06:36 AM   #25
Has the situation arouse when you needed the selectable?
Itchy feet is offline   Reply With Quote
1997 Ford E350
Fool120
Rex
Tomboy
