Old 11-23-2011, 11:56 AM   #11
Re: Loaded Roof Rack on Pop Top
webbmac - I believe those tube supports are standard now on the manual PH. At least they were on our 2007 build.
Old 11-23-2011, 05:05 PM   #12
LenS's Avatar
No one said anything about them when we had penthouse installed in 2009. Did not know they existed.
Len & Joanne
The Green TARDIS
Old 11-23-2011, 05:43 PM   #13
That maybe a difference between Indiana and Fresno.
Old 11-23-2011, 10:45 PM   #14
Yep, my van was built in Indiana in '08.
webbmac is offline   Reply With Quote
Old 11-25-2011, 12:17 PM   #15
Kayaker's Avatar
Those supports where not recommended for me at the Fresno Factory because of the possible large amount of weight that I'd like to have on the roof while it is up. They actually recommended I do the 2x4 option and not purchase these drop down legs from them.
'02 Sportsmobile E350: Quigly 4x4, Pop-Top, 7.3L Diesel
www.ExploringElements.com
Kayaker is offline   Reply With Quote
Old 11-25-2011, 04:38 PM   #16
joey2cool's Avatar
Standard on manual pop top from SMB West in 2010 too.
The only reason I can see SMB Indiana saying use 2x4s is if they can't give you something that will hold the weight you want. So basically you're on your own and they can say whatever they want. However, if I were them I'd cover my ass and put the standard metal tubes in with the written weight limit that comes with them and then tell you what you can do to work around this weight limit.
Silver Bullet
joey2cool is offline   Reply With Quote
Old 11-25-2011, 08:37 PM   #17
larrie's Avatar
An alternative to 2x4 might be wooden closet rods. They come in 1-1/4" and 1-1/2" diameters and look much nicer.
Larrie
89 Ford 2WD penthouse
Larrie
Old 12-21-2011, 03:38 PM   #18
Kayaker's Avatar
How tall are the corner supports people have made/SMB has? I need to get something sorted in the next few days and figured a height to start with will give me better options when I head to the hardware store.
Old 12-21-2011, 10:50 PM   #19
Viejo's Avatar
Your best bet is to raise the top and measure. Measure each corner!
Mine varies about 1" front to back and about 1/2" side to side in the rear.
When I cut the 2x2 sticks for mine I just measured the front right corner and
cut 4. Luckily that corner was the longest and the others just needed a little trim.
2002 E350 7.3 PSD
Quigley 4x4, EB50 floorplan
Old 12-25-2011, 07:37 PM   #20
Used 1" aluminum tubing with rubber end caps like the ones on the end of a cane. Very light and very strong. Got it all at OSH.
Vanna
gahamby
"Campy"
campy
