Old 12-05-2015, 10:02 PM   #41
Re: Rack 'Em Up (or, A Collective Bump to Bike Rack Threads)
Thx.
the Kuat 4 carrier may need to go back to the front though. my front receiver seems to be mounted at a slight upward angle, which makes for excellent approach angle clearance with 4 bikes in front.
My only concern with this is if the rack ever failed (it sometimes takes a few tries to "click" back into the raised locked position after being dropped, which worries me) at highway speeds, it would be a mess.
steven3 is offline   Reply With Quote
Old 12-06-2015, 09:47 AM   #42
Here is a video of a product called the Silent Hitch Pin. There are a number of products like this on the market. Both of my bike racks have a spring nut in the 2x2 tube and when tightened up with a wrench, stay very quiet and solid.
Old 12-06-2015, 01:45 PM   #43
tlg
tlg's Avatar
Steve_382: Unfortunately, the longer hitch extensions are built with a solid shank and won't accept anything like the Silent Hitch Pin. Picture of the Blue Ox Immobilizer II attached. Barely enough clearance to get it on but managed to make it work. On a side note, I found putting a strip of grip tape on the hitch extension kept my foot from slipping off. I end up standing on it quite a bit when accessing the rear of the rig.
2014 Ford RB-50
Old 12-06-2015, 02:45 PM   #44
Just a thought, but could you drill and tap the solid shank? It would be a lot of drilling, but could work the same way.
Old 01-12-2016, 11:33 AM   #45
Ok, I finally got a rack in place which I like!
Notice I had to move my license plate, but here she is:
This rack will swing out of the way WITH BIKES on it. It is a bit spendy, but totally worth it to be able to carry bikes safe and stable!
Cody is the man behind the rack: Recon Rack Co
He can make it so you can still accept a trailer as well, he will do custom work, and his stuff is super solid. Mine is just the latest in a long list of happy rack owners.
2014 Black Ford E-350 V10 QuadVan getting built in Spring
2010 Ford Raptor 6.2L
prally is offline   Reply With Quote
Old 01-14-2016, 09:29 PM   #46
I ran across this today... From 1973 Popular Mechanics.
Seems like our safety standards have increased just a tad in the last 40 years or so. Haha
ert01 is offline   Reply With Quote
Old 01-15-2016, 07:35 PM   #47
sierraskier's Avatar
That is pretty bad-ass.
sierraskier is offline   Reply With Quote
Old 01-29-2016, 03:03 PM   #48
Hi Prally,
That appears to be exactly what we are looking for. Any chance you could snap and post a photo of the rack when it is swung out? Seems as if the bike is supported by the front tire; any concerns about this or locking the bikes up? Cheers
lulupass is offline   Reply With Quote
Old 02-01-2016, 11:43 AM   #49
Originally Posted by lulupass View Post
Hi Prally,
If the wheels were straight, then this would be a no brainer yes. The wheels hold the rider at high speeds and over all types of terrain. In order to make the handlebars clear though, this rack has angled the front wheel creating a bit more lateral strain than normal. For mountain bikes with much wider/stronger rims, this is not an issue. I would be a bit more cautious using this rack with a road bike though.
I don't have any open photos, I'll post some though when I can. I can assure you though that the rack clears the box and tire perfectly.
As for locking the bikes. I lock them to the receiver with a chain or cable depending on where I am and how long the bike(s) may be unattended. No issues, but the distance is a bit far, so make sure the chain or cable is not swinging against your bikes, etc.
Old 02-01-2016, 05:17 PM   #50
alta825's Avatar
How's the swing out work with the spare/box? Can you open both sides with the bikes loaded up? Been eyeing the Recon Rack since i saw a few last summer
If you could snap a shot of the side view that would be terrific
Thanks a Ton
-d
2002 EB51 7.3L w/ Stage 2- UJoint 6" 4x4 Conversion
2001 RB50 V10 Quigley- SOLD
alta825 is offline   Reply With Quote
