Old 06-15-2021, 10:18 AM   #1
PNWVAN's Avatar
WTB Rear Captain Chair
I am looking for a rear seat for a child seat. Preferrable one that would mount in with no fabrication.
What do you guys have? I am located near Seattle but would be willing to drive a bit for the right seat.
I have 2 Sienna seats in the garage, would also take a floor mount for one of these if someone has one
Thanks
PNWVAN is offline   Reply With Quote
Old 06-15-2021, 10:36 AM   #2
04QuadBear's Avatar
UJoint still sells the bases for the Sienna recliner seat. i just got mine from them a little while ago.
04QuadBear is offline   Reply With Quote
Old 06-15-2021, 10:43 AM   #3
PNWVAN's Avatar
Thanks. Did you have to drop the fuel tank to mount the one behind the drivers seat?
Any pics of what you did under the floor, IE backing plate etc?
Old 06-15-2021, 06:43 PM   #4
BrianW's Avatar
I mounted one inside the barn doors on both my previous 98 and current 2011 SMBs. Not terribly hard, just make sure you use the proper approved hardware. You can kinda see it in this photo, partially swiveled.
Old 06-15-2021, 10:11 PM   #5
larrie's Avatar
I have two Ford seats that should work. One is for the drivers side and one for the passenger side. Have one standard base, maybe two, and one swivel base for them. Am in Oregon City.
Larrie
Old 06-16-2021, 08:34 AM   #6
PNWVAN's Avatar
Larrie sent you a PM
Old 06-16-2021, 10:18 AM   #7
04QuadBear's Avatar
I have a transfer flow oversize 44 gal tank the inside back and front bolts are a challenge to get nuts and washers on but it can be done. I used 1/4" aluminum 4" washers on the underside. Top side, if the mounting bolt lands in a valley I use a piece on 1/4" aluminum 2" wide to level out the valley.
Old 06-20-2021, 10:07 AM   #8
We ended up using seats from a Ford Transit. It’s pretty easy to find brand new ones that are taken out when people convert the vans for work or camping. We liked this method because they had integrated seatbelts and anchors for car seats. I paid someone to install just to be safe but it really wasn’t that complicated.
RemingtonM is offline   Reply With Quote
Old 06-20-2021, 10:33 AM   #9
Weld-tec designs offers an aluminum plate that bolts into the factory seat mount holes and has brackets welded to it to use the Sienna quick release mounts. A little pricey but makes mounting the Sienna seats true bolt in
fjmatt73 is offline   Reply With Quote
Old 06-20-2021, 12:01 PM   #10
Rear captain chair
I have a brown leather, reclining, swivel, removable chair. The bottom plate mounts on the floor and the chair and post can be easily removed. I assume it was the original. The van is a 2004 E 350 SMB. If you are interested I can send photos. I live in Ketchum, Idaho.
lolo is offline   Reply With Quote
Tags
captain chair, rear seat, seat, seat base
Tatonka
gephoto
ClifFord
EliMakes
