Old 08-30-2020, 02:14 PM   #1
To Lift or not to lift
Hey Forum, I would like to get you’re thoughts on both the pros and cons and what to expect if I did a lift on my new SMB. I’m considering a 3 inch lift on my 2008 GMC Savana Dura max diesel SMB. The main reason for this is to do a bigger off road tire. The tires and height it currently sits at drives great and looks pretty cool so I’m a little concerned that If I lift it and go to 35 tires and custom fuel wheels what this could mean to steering and drivability. Any input or suggestions would be appreciated.
Thanks
Joe
41A52986-3D95-45D7-9B55-C1E6CFD2B9CE.jpg   DD98C54C-2AEB-4F26-9B4B-C36CB3173467.jpg
Jdkh2001 is offline   Reply With Quote
Old 08-31-2020, 08:17 AM   #2
marret's Avatar
Nice rig. Quigley 4x4? Already have a lift?
I lifted my 2008 Quigley with no lift and have no regrets. 33” tires though. Upgraded my rear springs, shocks, and tie rods as well. Weldtec Designs did mine.
https://weldtecdesigns.com
Boulder Offroad for the lift as you are in CO?
Not asking the same questions, but here is a thread I started a while back about this:
https://www.sportsmobileforum.com/fo...mpg-20822.html
Chris
Old 08-31-2020, 09:56 AM   #3
WhitH's Avatar
What size tires are you currently running? Mines a short wheelbase like Marrets, but I lifted mines and found the ride to be better in the front and don’t feel like it compromised stability at all. I did upgrade the shocks at that point so it likely offset the left.
Sold 2005 E350 Chateau
Old 08-31-2020, 10:14 AM   #4
Hey WhitH, my van currently has LT265/75 R16.
Old 08-31-2020, 10:25 AM   #5
WhitH's Avatar
You can easily get enough lift to run a 33 ish by just changing out your torsion bar levers/keys in the front and by adding a small block in the rear. Contact Quigley for your build sheet and ask them the GM part number for the front levers/keys. I posted the info in my thread when I did it. I can look it up if you cant find it. I would suggest though if you’re willing to spend a little, going to custom rear leaf pack as Marret suggested from Weldtec. You can also go whole hog and get the full front lift kit as well.
Old 08-31-2020, 11:14 AM   #6
Thanks again Whit, I actually have my quigley build sheet I’m going to forward them what you said and see what they say.
Old 08-31-2020, 11:20 AM   #7
marret's Avatar
What I like about Weldtec's lift is the lift being accomplished with a longer knuckle and revised subframe for the front differential/suspension instead of lifting by torsion bar. Definitely not cheap and many do the lift through the torsion bar route.
Chris
Old 08-31-2020, 11:22 AM   #8
Thank you for all the good info.
Old 08-31-2020, 02:45 PM   #9
As a person who has lifted pretty much every vehicle I've owned, I have to ask: why do you want to lift it? Why do you think you need 35" tires?
If it's just for cosmetic reasons, I still won't argue with that, just curious if there is a performance shortfall you're trying to overcome?
Old 08-31-2020, 04:09 PM   #10
All cosmetic all about resale and I have decided on only a 3 inch lift and 33 tires. Thanks for you’re advice and input I really appreciate it
Jiminy
Gooseberry
AWOL
Twoxentrix
