Bullfinch Shower Point No. 6088 - No Water :(
Hi friends,
Wife and I acquired a Sportsmobile equipped with the outdoor shower. Previous owner said he just plugged in the shower and it worked, although he said he used it only once. I've tried every valve in the rig, had pump on, had heater on, traced water lines, and am at a loss. The "less than informative" SMB sheet says there are two switches, like a hallway, but I can only find the one pump switch for the sink.
To note, around where the city water connects, right next to the shower valve, there are two water lines that run to the underside of the vehicle. When I turn them, water leaks to the ground, telling me "I should" have water at the valve.
Do the valves go bad often? Any way to check/test?
Thanks all.
