Scatter here is what the invoice said:
RETRIEVED CODE P2290 ICP LOW. MONITOR THE DATA LOGGER. ONLY 52 PSI. LOOK UP OASIS FOUND TSB 8-16-6. PREFORM AIR PRESSURE TEST AT THE PUMP HAS LARGE LEAK. NO CHANGE WHEN CYCLING THE IPR. REPLACED THE IPR. CLEARED CODES. RETEST PASS. ROAD TEST PASS. STEAM CLEAN.
FP NUMBER 5C3Z-9C968-CA----------------REGULAT 135300-------QTY-1
W300013-------------------------BOLT 848795-------------QTY-1
W300051-------------------------NUT-L 845202------------QTY-1
[EDIT] Ford said they did replace the ICP sensor while in there
BTW Ford charged me 100 bucks but sent me a check back for 100 dollars.
Dave.
