Hey guys
After my wife was pushing for an awning I took my chances and „explained“ her we‘d need a roof rack. She agreed and that‘s what followed!
I started ordering my Fiamma via 1der/ Ray and knowing there may (!) be some lead time, I started to think about my rack.
25kg/ 50lbs per crossbar, as low as possible, as flexible / versatile as possible,…
—> I decided for extruded aluminum profiles.
I went for 4545 profiles, got 5x 13ft from Grainger and all bolts/ nuts are M8!
Gutter clamps are the 90 degree Smittybilt HDS. 12 in total, 6 crossbars.
I aligned them and only had to shim a single one (all bars are ~2‘ apart), the 4th from the front.
Ray gave me instructions about how high it should sit above the rain gutter, so I decided to put the long side bar on top of the crossbars to achieve the relevant height.
To connect it I used regular connectors, 1x M8 each side.
Seeing the Fiamma brackets I decided to go for an additional M12 in the crossbars. That‘s just what thebinner hole of the 4545 provided.
In general it‘s adding to avoid momentum; not really needed, but hey: 20$ atop of the other 2K…
Ray was a bit concerned about 35‘s + 6“ lift anf the length of the legs, but it‘s easy going: I got 30cm left!
Clearance between the Fiamma and rain gutter is ~2.5“, so easy going.
Here are some pics, let me know when you have more questions.
(Rear 40 door)
(Gap between 40 and 60 door)
(From the front corner of awning)
(Front awning)
