Originally Posted by martinli
I know we already had this discussion in one or more different threads.
The conclusion for 2008+ E-Series Vans is this :
- ForScan will not work
- the RPM data are taken from the ABS sensors and not only from the diff or transmission
- programming the ABS module and changing the odometer reading seems never been provided by any Ford dealer
- the one and only way - as far as I know - is to use a SCT X4 tuner together with a custom tune from 5star. This worked for me and a couple of other folks.
I asked the seller about this VCX Nano supporting Econolines. He answered in the affirmative for 2005 Up Vans.
I don't know if this dealer-level tool will work to change the VSS scaling but it might be worth a try. The dongle costs about $95 and the subscription is $49 for a day.
For my purposes on a 2000 E-350 I plan to try a Arduino clone with some frequency convertor code spliced into the VSS output of the ECM. I will be able to extend the wires with access under the hood and locate the Arduino in the cab. This would then only affect the Dash and the Cruise Control Servo.
Your previous message
>>>>Support both new and old vehicles from year 2005 to 2022, For Ford F series after 2010.
Does this support Ford Econoline from 2005 thru 2014?
New message from: underrepair2020 (740 )
yes,it supports
https://www.ebay.com/itm/15520688475...&segname=11051
Understanding Ford’s F-Series VSS Systems
On an AC, permanent magnet sensor, both AC voltage and frequency increase with the speed of the trigger wheel. The AC voltage should range from 0 volts at 0 MPH to 3.5 volts at 30 MPH.
Frequency should increase from 0 Hz at 0 MPH to about 125 Hz at 55 MPH.
125/55 = 2.272727 Hz/MPH
Understanding Ford's F-Series VSS Systems
https://www.f150forum.com/attachment...-explained.pdf
