Old 12-14-2023, 11:14 AM   #1
FORScan
Does anyone have experience adjusting Odometer/Speedomoter settings with the FORScan to adjust for non-standard tires in E-350 vans? What interface module is required/recommended?
Bundy is offline   Reply With Quote
Old 12-14-2023, 07:33 PM   #2
Nice to know this is and option.
https://forscan.org/forum/viewtopic.php?t=15994
This looks pretty easy for a new 2018 F150
https://www.google.com/search?q=Re%3...Ne_aLr-_A,st:0
posplayr is online now   Reply With Quote
Old 12-14-2023, 07:42 PM   #3
I don't think it works on 2008+ vans.......1der and I tried it on my van and got nowhere...and I think others have had similar results. It was a long time ago, so maybe things have changed. I seem to recall the speedo calibration was in the ABS module in the newer vans, or something like that.
Old 12-14-2023, 07:49 PM   #4
Here is someone asking in 2018 with no response for a 2012 E-350.
https://forscan.org/forum/viewtopic.php?t=7512
A thread from here is no resolution for newer vans.
https://www.sportsmobileforum.com/fo...4-a-27851.html
Old 12-15-2023, 03:43 PM   #5
I tried to adjust it in Forscan as well a few months back on my 2011. Didn't work. Then I tried to adjust it via my 5 star tuner and that also did not work.
Old 12-16-2023, 01:14 AM   #6
schluchtenflitzer's Avatar
I tried it on a 2001 powerstroke with no result
www.Dieda-unterwegs.net
schluchtenflitzer is offline   Reply With Quote
Old 12-16-2023, 09:54 AM   #7
Another recent link for a 2008 E-350 with no luck. A Heads Up GPS display would probably be a second best option.
https://forscan.org/forum/viewtopic.php?t=24808
This is an example of a GPS dash unit. I have not seen a GPS/OBDII combined unit.
https://www.aliexpress.us/item/32568...440001152966_6
Old 12-16-2023, 11:20 AM   #8
Nobody has done a lot of work to document as built information on these older vehicles... especially the vans. You may be able to research 2008s that have the features you want and then reverse engineer the asbuilt changes. You can buy an IDS one day subscription but you need the right adapter. Maybe a good independent shop with IDS can help. Dealerships seem to walk away from these things.
The link above mentions IDS. This is the Dealer level diagnostics and programming system.
https://www.fordtechservice.dealerco...ury%20vehicles.
Old 12-16-2023, 11:28 AM   #9
I do have a 2011 E-350 but no immediate need for this. It is only $95 shipped and you still need the subscription to the Ford IDS. If I have another requirement I might get one. I don't plan on putting oversized tires on the 2011 and everything else is pre-2005 which is the cutoff for this device.
https://www.ebay.com/itm/15520688475...8AAOSwDRpjRVnn
Seems to be a knock-off of this.
https://srs20assets.bosch-automotive...333.1701575845
The subscription process is here.
You can see more about Software Licenses here.
Be sure to review the entire Terms & Conditions when you establish an account.
365 day IDS/FDRS Software License = $849.00 per license
30 day IDS/FDRS Software License = $299.00 per license
2 day IDS/FDRS Software License = $149.00 per license
365 day FJDS/FDRS Software License = $849.95 per license
30 day FJDS/FDRS Software License = $149.95 per license
2 day FJDS/FDRS Software License = $49.95 per license
https://www.fordtechservice.dealerco...cs/default.asp
Old 12-16-2023, 11:34 AM   #10
There are also knock off VM2's with high positive reviews
https://www.ebay.com/itm/196048740850
https://www.ebay.com/itm/17603468009...Cclp%3A4429486
Product Description:
VCM2 2 in 1 for Ford and for Mazda IDS V121 Diagnostic Tool VCM 2
Notice:
1. Softwares for Ford and for Mazda can't work in one computer.
2. Please install the VMware software firstly, and then install the software for Ford in the VMware station.
3. Please change the computer time zone to China time zone
4. Computer configuration: WINDOWS Win7 32bit system, and at least 4GB Memory and Dual Core. It can't run in win 8 or win 10.
5. This VCM2 doesn't support for ford F series cars. pls take notice. thank you!
VCM 2 Scan tool can do diagnose, scan, airbag, key programming, ecu programming, PCM programming via OBD2 port.
Support VMM and CFR , do not support F250
Provides full dealer diagnostic capabilities to Most 16pin cars 1996-2016 for Ford (can't do 24v vehicle.) including for some new 2016 vehicles. Supports the car after 1996 for Mazda.
pdate via link ( we will send the link to you to download the newer software )
VCM 2 Features:
1. The VCM 2 is the new OEM diagnostic tool. It provides dealer-level diagnostics using the IDS software.
2. The VCM 2 is the brand new diagnostics interface from for use with the Integrated Diagnostics Software (IDS).
3. The VCM 2 and IDS provides full dealer diagnostic capabilities for most 16 pin .
4. The VCM 2 will be required for all new 2013 vehicles and is backwards compatible with most 16 pin Fds.
It supports the Vehicle Measurement Module (VMM) and new Customer Flight Recorder (CFR).
5. The VCM 2 has shock resistant rubber ends, making it suitable for garage and workshop environments.
6. The CFR replaces the Vehicle Data Recorder (VDR). 7. The CFR is an optional cable that allows the VCM 2 to monitor and record live data streams. This provides an advantage for technicians when diagnosing
VCM 2 Function:
-Automatic vehicle recognition
-Read & Clear Diagnostic Trouble Codes (DTCs)
-Live Data-stream with Recording & Playback Functions for Main ECUs
-Guided Fault Finding
-New Software Re-flash for Existing ECUs
-Programming & Installation of new ECUs (PCM, ABS, Instrument Cluster, Air Bag, Fuel Pumps, etc.)
-Program New Keys
-Injector Coding
-Set, Adjust or Remove Speed Governors
-DPF Regeneration
-Brake Bleeding
-Steering Angle Resets
-All Other Dealer Functions
VCM 2 Package List:
1pc x VCM2 interface
1pc x OBD2 cable
1pc x USB cable
