Originally Posted by doublevan2
Then are the water heaters from threads (Home Depot - Bosch) the same "problem" - no bottom drain on these units ?
Some are and some aren't, from my research when I was looking for one. Most of the point of use style like you linked are designed for a residential (climate controlled) under sink environment in a house so they really never need to be drained and the manufacturers have quit putting drains in them. At least that's my understanding.
The 300W 12VDC element overheated the fuse and melted the plastic fuse block.......200W element has been working great since the change. If you use something physically larger than a std ATO automotive type fuse I'm sure you could use a 300W element.
I went with this 300 watt linked below and it's been working great but I did run 6 gauge cable from my bus bar and a 40A maxi-size automotive fuse IIRC.
I've been very impressed with how quickly it heats up the 6 gallon tank and how little it taxes my 300ah of lithium.
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
