Old 02-02-2024, 08:28 AM   #1
Requesting Part number ebrake parking emergency cable e350 ford extended body
I just put a full floating axle from a 1999 into by 2006 that had a semi floating axle.
The parking brake cables have different ends on the 1999 (hook) vs the 2006 (loop).
Appreciate if anyone has a cable from a 99 EB or a part number.
Old 02-02-2024, 02:47 PM   #2
Need a left and right rear cable. See pics.
Old 02-02-2024, 05:25 PM   #3
I think I found them:
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
Old 02-03-2024, 02:12 PM   #4
Here are the pictures of the cable off of a 1999 E350 EB.
It appears that there is an extension cable (about 18" long) that is not on the earlier Drum RB. I realize this is not related to the difference in length of RB/EB because the wheelbase is the same.
There are these special clips to hold cable ends back top back at two spots.
The curt cable is the cable that comes from the EBrake cable at the driver's seat.
Old 02-03-2024, 04:34 PM   #5
Thanks for the pics. I ordered these.
Hope it’s the right one.
https://a.co/d/dE47B2M
https://a.co/d/3AlQRpe
Old 02-03-2024, 05:53 PM   #6
These are pictures of a 2000 E-350 EB (rear disk brakes); the other was my spare 1999 E-350 EB (also disk brakes).
You have the correct parts (for left and right), but as you can see in the first picture there is another cable to connect the front cable to the rear. You need one more section of coated cable and one more of the end-to-end fasteners.
Old 02-03-2024, 08:55 PM   #7
Yes correct there’s many sections. I just needed the rear 2 cables. Appreciate the pics and post. Cheers ��
Old 02-08-2024, 11:15 AM   #8
Ford 2003 E350 EB 4X4 7.3 Sportsmobile
Question: My E-brake has never worked. Anyone have a similar issue. I had the system replaced at Ford dealer with the same results. I use the Parking brake.
Any recommendations for a solution?
HighCountryMike Ford 2003 E350 4X4 7.3 320,000m Still going strong
HIGHCOUNTRYMIKE is offline   Reply With Quote
Old 02-08-2024, 11:25 AM   #9
bigriver's Avatar
Yep - that is a known issue with these rigs. It would be great to hear how someone has remedied this.
Joe
2003 EB50 7.3L PSD Q4X4
2003 EB30 - Sold
Old 02-08-2024, 11:27 AM   #10
After doing some research it appears as if the Ebrake is very sensitive to the rear Ebrake shoe adjustment. If the installer is sloppy they can leave the shoe too loose and it will not grab adequately.
Also, the self-adjusting shoes don't adjust very well, so they tend to lose braking force over time.
One of the other concerns might be the mechanical pull mechanism getting rusty and not moving easily. There are only a few points where this could be a problem but some of these vans get pretty rusty.
I would have hoped that your dealer could have resolved this. I know it was recommended to buy a brake diameter measuring device to preset the shoes before pushing the rear disc on.
  • Westward 1Eka5 Brake Resetting Gauge
https://www.ebay.com/itm/22583254191...RoCyr0QAvD_BwE
