Old 02-10-2024, 12:59 PM   #21
If thru the bung hole is difficult, just pull the rotor..spin the star and reinstall rotor and give it a spin......rinse and repeat until you get a little drag.
As I recall, the rotor goes on much easier than it comes off if the shoes are a little too tight (expanded).
That's why I got the caliper.
Old 02-13-2024, 10:55 AM   #22
Thanks for this
Originally Posted by posplayr View Post
2000 Ford E-350 2A793 intermediate cable
Interesting things in the 2000 FSM. There are several variations, but one figure shows E-150 and E-350 as the same with an intermediate cable.
A search shows up this (Rock Auto).
Parking Brake Cable - 2000 Ford E350 V10
  1. ACDELCO 18P1974 Gold / Professional
  2. RAYBESTOS BC95459 Parking Brake Cable
  • DODGE B1500 1995-1998
  • DODGE B2500 1995-1998
  • DODGE RAM 1500 VAN 1999-2003
  • DODGE RAM 2500 PICKUP 1999
  • DODGE RAM 2500 VAN 1999-2001
  • FORD E-250 2000-2006
  • FORD E-350 1997-2006
  • FORD ECONOLINE SUPER DUTY 1996-1998
Old 02-13-2024, 11:06 AM   #23
Originally Posted by Ocsmb View Post
Thanks for the pics. I ordered these.
Hope it’s the right one.
https://a.co/d/dE47B2M
https://a.co/d/3AlQRpe
my driver side rear stock cable is 76" in length. So, previously, it didn't require an intermediate cable. The aftermarket one is 58". 18" difference which means now I need to run an intermediate cable.
So funny how Ford does things.
Old 02-14-2024, 04:02 PM   #24
SierraHawk's Avatar
The parking brake is essential but mine did not work even when new. I figured it was due to a factory problem and began a series of adjustments that never lasted more than 5000 miles (van has 340,000 miles on the odometer) and even then I don't trust the parking brake to hold the van. I had the same problem finding a cable when I installed a full floater. I was lucky in that I found a small wrecking yard that had several Econoline vans in the back. The other problem is the clearance between the "hat" and shoes has to be adjusted to less than 1mm without a feeler gauge. Even when adjusted correctly, mine quit grabbing iron after about 5000 miles. Remembering to release the parking brake is another matter. Unless you are lucky enough to locate the cable online best bet is to pick through a junk yard. Ford built millions of these rigs so there has to be one you can cannibalize somewhere in the sagebrush east of LA. The ends are unique to Ford so improvising is a bit more difficult. The cables have little to no stretch in them, so it is preferable to use OME if you can. Ultimately, the real problem shows its ugly head is when parking on a hill. If someone, a kid or a dog pops the transfer case lever out of gear, you got a whole lot of other problems to deal with. The only solution I've given any thought to is installing a wraparound "shoe and caster wheel brake" and lever onto the rear driveline. It will take a drive line shop to weld everything in place and rebalance the driveline. It is an old school solution but the kits are still available.
SierraHawk is offline   Reply With Quote
