Originally Posted by 86Scotty
I like that Sherman cap! A few have posted, and I was already aware, of the rubber/plastic type caps on a tether like your second two links. The problem I see with those is that water/mud/sand get into the back (spring loaded) part of the couplers are eventually ruin them. I like that the Sherman cap completely encapsulates it. Cool design.
Eric, If you decide on the Sherman cap;
They are very well made. I ordered 4 a couple years ago so had a chance to handle them. My only suggestion would be you locate a thin flat rubber washer that would fit around the base (at the bottom of the threads), so when you screw the cap down on the base the rubber provides some resistance preventing the top from backing-off through constant vibration. I actually located washers which worked perfectly at a local Ace Hardware (EDIT: It may have been a West Marine). Ultimately I went a different route, and returned them.
