08-27-2013, 07:15 PM
#1271
Re: What did you do to your SMB today?
Yeah, I still need to get a good shot of the new storage box, but this afternoon my Bus Depot awning came in and I set it up to test fit.
Seems to work great. Takes about as long to put up as s small tent. Clamps easily to the rain gutter when the PH is up. In this pic I tried using their drive over brackets. It worked for the rear, but not even close for the front, but I can bolt the legs to the nerf bar brackets front and back for a clean, no guide line setup.
08-29-2013, 06:25 PM
#1272
Cleaned my top for the first time today with a power washer.
Len & Joanne
The Green TARDIS
08-30-2013, 10:57 AM
#1273
Finally got around to writing the fresh water tank directions on the tank itself and numbering the valves
Steven McKenzie
Madison, WI
2013 E350 EB-44, V10 6.8ltr
Toyo LT285/70 R17
08-30-2013, 10:54 PM
#1274
DP Tuned with a new egt probe and touch screen. Not sure I like the smoke but I bet you cant get that dollar off the dash.
I do like the shift points over the Superchip tune I had. So back to the smoke and I now have on order the IH belowed up pipes to fix a few leaks that I had fixed a couple years ago.
I might just have the superchip tuner up for sale
08-30-2013, 11:25 PM
#1275
Originally Posted by Gooseberry
... So back to the smoke and I now have on order the IH belowed up pipes to fix a few leaks that I had fixed a couple years ago.
Not sure these will fit vans, but RiffRaff Diesel sells ceramic coated IH up-pipes. Wish I had known about these when I had my leak fixed.
http://www.riffraffdiesel.com/mm5/merch ... F731-EP-IH
08-30-2013, 11:52 PM
#1276
looks like the same ones but thats over 200 more green backs for the ceramic. It cost me over $500 to have the last leak fixed last time and these I can put on pretty quick at a cost of $320 so I'm happy not to have to worry about those dam bushings anymore.
Your right I wish I knew about this issue with the 7.3
08-31-2013, 07:57 PM
#1277
Installed Spec-D headlights with LED DRLs. Really like them so far. Also installed the clear corners. Picked them up off eBay for under 100 bucks!
Finished wiring in a gentex mirror with temp and compass.
09-01-2013, 04:02 PM
#1278
Ran kerosene through the furnace. Supposed to clean out the combustion chamber so you never have any more problems....
Scatter
2007 RB50, 6.0
K1WGB
09-01-2013, 08:16 PM
#1279
Skyl330 those look sweet! Any way you could post a pic a little more from a distance? Maybe outside in the daylight. I'm curious what they look like in better light. Even they Ebay page's pics are pretty dark.
Thanks
09-02-2013, 11:46 AM
#1280
I have had this insulation foam from a friend that does aerospace stuff. It is 1/8 inch thick with a sticky side.
Always looking to reduce the cycle time on the Norcold I finally cut the pieces and went from this
To this. The back I covered as much as I could.
I'm hopping that it also quiets the fridge down a little more.
