Old 04-21-2023, 10:59 AM   #3391
Any chance of a nice - wide angle shot - of your bed/cabinet/seating layout ? Locking cab's look nice. Thanks -
Old 04-22-2023, 09:48 AM   #3392
The layout is a EB27 with the big high top. The original purchaser/builder of this Sportsmobile picked a great layout and options. From the factory propane delete was added which I love. I’d rather cook on a simple burner stove which allows me to cook outside on hot days. The diesel heater I installed works great for heat. I like that the sink in out of the way in a corner. The camper had a cassette toilet in the far back left corner. About 4 months ago I swapped it out for a sun mar composting toilet and it’s been great. The sun mar is very compact and it fit the space perfectly. I sleep up in the top penthouse diagonal as this lets me stretch out with lots of room, it’s a cozy little cave.
Originally it had seatbelts for 10 with the full build intact. There were 2 captain’s chairs behind the drivers seat. They are mounted on quick disconnect plates. The couch cushions i removed was only 2 bolts and the boxes are bolted to the original metal frame of the couch so I could convert it back to the 10 passenger camp mobile easily. I do feel kinda bad owning this as it would be a great van for a family with kids.
5DB548BE-546B-4B66-9C87-E468BCF65FF1.jpg   D330E953-26F9-459A-A55F-2D84F599BE9E.jpg   DE0497A7-51E3-4091-8D2D-B3527CAEF266.jpg   0AD5626C-7EB4-4D7B-BC51-DDF8C4842AC2.jpg   7DD2E66E-DFA7-49AB-A095-14A79D09C452.jpg
824E0898-FFFC-4473-9B18-B26425A4A973.jpg   C89E7004-5EF4-474E-B47E-F5837FE3FABA.jpg
Lazy_Daves is offline   Reply With Quote
Old 04-22-2023, 12:07 PM   #3393
I did this upgrade a little while ago. Tiny Garmin Dash Cam Mini 2 powered off the rear view mirror Temp/direction display harness. The 12v to micro usb plug really cleans up the wiring for it.
E8A1B02A-F010-4A2F-A32A-0BC670E0021C.jpg   8D11C2E6-3336-4CEA-BDD7-48E656D1B756.jpg
Old 04-22-2023, 06:56 PM   #3394
Lagun Table mounting plate
I just posted photos of the Lagun table steel mount I had made. In case anyone can benefit. It seems to be a great solution as a replacement for the tripod base and mast table.
rtamobile is offline   Reply With Quote
Old 05-08-2023, 09:30 PM   #3395
250$ well invested: new vapor canister and gas station visits are a walk in the park [emoji23]
Since buying the van I had multiple stops while fueling up, getting worse the past months and I even got a warning code during the past two drives.
Disconnected one hose each side, clicked it out, clicked it in, connected two hoses and there we are: 22 gallons with out interruption [emoji869][emoji23]
Old 05-08-2023, 09:33 PM   #3396
vandiesel's Avatar
I missed what you invested in?
Old 05-08-2023, 11:10 PM   #3397
Got a new vapor canister ;-)
Old 05-09-2023, 06:49 AM   #3398
Cluster swapClick image for larger version
You can follow my build
Instagram @TheDirtVan
YouTube- TheDirtVan
https://www.youtube.com/channel/UCSePTshSLn79BOCGYwSwPbQ?view_as=subscriber
NoR32 is offline   Reply With Quote
Old 05-09-2023, 09:05 AM   #3399
I wish my fill up troubles were that easily fixed! Glad it worked out for you
motovan_mn is offline   Reply With Quote
Old 05-09-2023, 09:14 AM   #3400
Motovan....have you replaced your vapor canister? I have this issue but it's not too bad and somewhat intermittent. Once in a while it clicks off the pump.
