Old 04-16-2020, 08:37 PM   #2971
gahamby's Avatar
Now there's one I need to look into. The drivers seat in the GMC needs replacing.
'07 GMC 2500 6.0
Old 04-18-2020, 06:02 AM   #2972
Look into these guys: They seem to know their stuff and have new foam for sale too.
HTH
Old 04-18-2020, 08:17 PM   #2973
NavyNuke's Avatar
Painted the inside of my fiberine roof, finally!Click image for larger version
ID:	32850Click image for larger version
ID:	32851Click image for larger version
ID:	32852Click image for larger version
NavyNuke is offline   Reply With Quote
Old 04-19-2020, 12:35 PM   #2974
Twoxentrix's Avatar
Lot of major electrical under my goucho, and have wanted to install some sort of fire protection - the Blaze Cut Fire Suppression System came up in a discussion last year some time, and I found the concept interesting.
Ordered one a couple weeks ago and installed under the bench this morning - Purchased the 6ft model & ran it past my Dual Amps, next to the panel with all the fuses, across the top of both the Espar & Inverter, and finished up just above the breaker box.
These have a 10yr life expectancy, and a small gauge at one end which displays the charge status (just like a fire extinguisher).
***Hopefully I'll never have to produce a follow-up on its effectiveness!
Old 04-19-2020, 08:47 PM   #2975
jredone's Avatar
Put in some Molle stuff
Coverking seatcovers
Overland gear guy for the door panel
4988BE3F-6D3B-4678-80FD-91A16B1C96B5.jpg   3D7E1856-F26E-4320-9BE0-CA72E21D1094.jpeg
jredone is offline   Reply With Quote
Old 04-19-2020, 10:10 PM   #2976
sbgrimm's Avatar
We all need more storage, right? And shoes, what do you do with them? Well, the replacement of the SMB top with the Colorado CamperVan top gave us 5 additional inches of height under the penthouse bed. This allows the new space above the cabinets to perfectly fit 5 plastic shoeboxes for my spouses shoes, as well as other miscellany. Unfortunately, my feet are too big for these to fit my shoes...
Also fixed the persistent rattle of the outside cable TV input cover by putting a screw through the door to hold it closed permanently. We've never connected to cable TV and never expect to, so this should be the end of that particular rattle. While I was working in that area I also swapped the outdoor 12v outlet with one of the indoor ones. The outdoor outlet cover never stayed closed, resulting in water and dust accumulating inside. I couldn't find the same size outlet online so swapping one of the indoor outlets was a good second best solution.
Bardo
2005 RB-50 5.4L V8 E250 "Blanca"
sbgrimm is offline   Reply With Quote
Old 04-20-2020, 08:58 AM   #2977
Steve C's Avatar
Bardo, that's a good use of space above the cabinets. Perhaps a matching white cabinet built with an overhang would be a little more convenient? You could either put doors on the front or leave it with easy access openings?
2001 Sportsmobile RB50 7.3
West Central Mountains, Idaho
Steve C is online now   Reply With Quote
Old 04-21-2020, 04:53 AM   #2978
Yes definitely hope you travel fire-free but like yourself I found the concept fascinating. The product itself seems well designed and will fit in smaller spaces which is where they'd be most effective. The gauge is helpful too---they can be equipped with a switch triggering a signal light or buzzer if the system is deployed.
I've toyed with the idea installing one under the hood in the engine bay---I don't have a lot of confined electrical areas so that'd be my choice of where to install such a system.
Old 04-21-2020, 09:33 AM   #2979
VanDickin's Avatar
Any chance that you could show us what it looks like installed? Thanks!
VanDickin is offline   Reply With Quote
Old 04-22-2020, 12:50 PM   #2980
Twoxentrix's Avatar
I considered the one with the switch, but seemed somewhat redundant - If I had a fire and this system deployed as intended, I know the lingering odor of the fire & burnt plastic would be obvious. Also figured my smoke detector would probably go off before this system would activated by fire - so I passed.
Initially planed to mount the tube to the bottom of the bench seat, but quickly realized I'd probably scrape it off at some point in setting up the bed, or I'd inadvertently rest the bed & tube on the gaucho frame and rupture the tube. As is, it runs across or beside potential problem areas - tube itself is very stiff so it doesn't bend easily.
Cool-Airo
mikewithered
Dodge
lugee
