Old 09-06-2022, 09:33 AM   #3351
Originally Posted by SheepShagger View Post
Made a ladder this weekend.
Very nice!!
Old 09-06-2022, 10:13 AM   #3352
marret's Avatar
Yeah, very nice.
Chris
Old 09-06-2022, 10:22 AM   #3353
Made a ladder this weekend. Still needs paint (Bedliner) But wanted one that mounted to the rack rather than gutter, there for making it a little higher and easier to get onto the rack. So making was the only option.
Very cool! I have grand plans of building a very similar ladder that mounts to my UJOR rack up top. I guess we're kind of stuck drilling into the pinch weld seam at the bottom though, huh?
motovan_mn is offline   Reply With Quote
Old 09-06-2022, 10:50 AM   #3354
SheepShagger's Avatar
You could use a sandwich style mount at the bottom so you pinch the "pinch weld" between two plates. The bottom mount is only there to stop the ladder flopping about not really designed to take load. I did think of doing that rather than drilling into the pinch weld. But in the end decided I wasn't worried about drilling into the pinch weld.
What ever you do, don't tie it to the frame, that's asking for a lot of trouble since the frame flexes vastly differently to body.
Old 09-07-2022, 12:15 AM   #3355
rltilley's Avatar
I got tired of making monthly payments so I paid it off. So now it’s mine. Mine!
rltilley is offline   Reply With Quote
Old 09-10-2022, 02:23 AM   #3356
What I did over the last few days...
I bought this old soul a little over a week ago, 111K miles and original down to the last bolt - stored indoor it's whole life very, very little signs of corrosion anywhere (except for tires). I drove it from Coure D'Alene Idaho West to the Oregon Coast then South to my home in Newport Beach CA with only a tire swap before the journey - it had a recent oil change. In the last 4 days I did the following:
1. gave it a very thorough cleaning, carpet shampoo next.
2. removed the original battery isolator and 27 year old (not kidding) house battery.
3. donated the microwave to The Goodwill, it was working.
4. removed the old Norcold - worked on 110, not on 12V, don't know how to fix it.
5. fixed the reading lights
6. fixed the rear penthouse j-hook
7. repaired the driver's side windshield washer jet it was disconnected under the hood.
8. installed a ReLion 100ah LiPo battery, needed to run an alternator wire to the rear.
9. hooked up the alternator wire to a Victron Energy Orion -TR Smart charger (non-isolated).
10. installed a Victron DC-DC Converter to charge the house battery when on share power.
11. installed a Xantrex ProWatt Pure Sine Wave 1000W Inverter.
12. installed a Blue Seas 12 circuit fuse block for soon-to-come led interior lighting.
13. Ordered a a 2-way Dometic refrigerator to replace the Norcold (if any of you wants the Norcold let me know - I believe it only needs 12v relay to get working on 12v again), yours for free but you have to pick it up.
14. ordered a GE combination microwave and turbo oven.
15. shampooed the couch upholstery, contemplating what to do about the front seats (replace or clean old covers).
16. tightened and/or. replaced a bunch of interior fasteners.
17. added a small shelf to the bottom of the hanging closet.
18. flushed the cooling system and i think it would be a good idea to replaced the belts hoses, water pump and thermostat and some point soon.
The van is in remarkable shape given it's 1995 vintage and more than anything needs the replacement of items that have aged beyond their useful life. Water came in the driver's side rear sliding window and that project is the very next one I will tackle.
josevillaluz is offline   Reply With Quote
Old 09-10-2022, 03:51 AM   #3357
marret's Avatar
Nice upgrades to bring it current josevillaluz. Sure looks clean.
Chris
Old 09-10-2022, 06:39 AM   #3358
Oogs's Avatar
Nice clean rig!
Oogs is offline   Reply With Quote
Old 09-11-2022, 05:07 PM   #3359
Added 3 USB chargers today
Charger #1: front dashboard, replaced old cigarette lighter socket. Voltmeter built in, power switch, 30W USBC + 18W USB 3.0.
Charger #2 passenger wall near cooktop, replaced cigarette lighter socket. No Volt meter built in. 65W USBC + 18W USB 3.0
Charger #3 drilled out a spot in the bear breaker box under the couch bed, new mount. Voltmeter built in, power switch, 30W USBC + 18W USB 3.0.
The volt meters help me see which battery the chargers are using. The house battery is lithium and has 12.8V output, while the starter battery has 12V when the van isn't running. I can't keep track of what is wired to what after I install it so this feature is nice.
PXL_20220911_194843345.jpg   PXL_20220911_201614776.jpg   PXL_20220911_214317344.jpg
Old 09-11-2022, 06:53 PM   #3360
Very nice!!
Originally Posted by marret View Post
Yeah, very nice.
Very cool!
Thanks. Got round to paint and mounting this weekend. Epoxy primer, then Raptorliner to match rack, flares, bumpers & running boards.
Woodstock
woodstock
Tatonka
gephoto
