Old 12-30-2012, 02:42 AM   #1051
What did you do to your SMB today?
Rigs looking better than ever Tapatio
Old 01-03-2013, 09:24 PM   #1052
notmiller's Avatar
Re: What did you do to your SMB today?
Made some mudflap mounts with "quick-release" flaps:
The mounts are made from steel and bolted to the pinch seam. The flaps are attached with wing nuts for easy removal.
notmiller is offline   Reply With Quote
Old 01-16-2013, 02:01 PM   #1053
Originally Posted by Pritikin
Update:
The rear view camera appears fixed. Watch out for installers who run electrical lines too close to your exhaust system!
Also watch out for installs too close to the wheel well. If you have a blow out the thrashing tire will rip any wiring or plumbing from its attachments. BTDT
Hanging Out
vlamgat is offline   Reply With Quote
Old 01-19-2013, 03:55 PM   #1054
larrie's Avatar
Bought two equipment racks. One is 20wx24hx17d and the other is 20x31x17. They lock and have air vents on the sides and top as well as some holes in the back. They are made from a heavy gage steel. Will have to plug the holes but they should make good storage boxes.
The next step is to get them painted and mounted but will have to wait till it warms up for the painting part.
ImageUploadedByTapatalk1358635778.029045.jpg   ImageUploadedByTapatalk1358635796.290417.jpg
Larrie
Old 01-19-2013, 04:43 PM   #1055
Zeta's Avatar
Finished a major service today: air filter, fuel filters, front diff and transfer case oil change. Also installed a blue spring for the fuel pressure regulator and one of these neat billet caps for the front fuel filter: http://www.mkmcustoms.com/60fuelfiltercap.aspx
Had a check engine light after all the work. So I flipped out and stomped around for a while before I noticed I'd forgotten to plug in the intake air temp sensor.
Z
'06 RB50 SMB Diesel
https://www.tomsinclair.net
Old 01-19-2013, 06:36 PM   #1056
Tapatio's Avatar
Z
What does that do/fix?
Callsign KK6GIY
Old 01-19-2013, 07:24 PM   #1057
Zeta's Avatar
Raises the fuel pressure to the injectors by 10-15psi. Supposed to help protect the injectors.
Z
'06 RB50 SMB Diesel
Old 01-19-2013, 09:34 PM   #1058
Raises the fuel pressure to the injectors by 10-15psi. Supposed to help protect then injectors.
Z
Been there done that...according to Ford
Old 01-23-2013, 12:11 PM   #1059
Originally Posted by CJ
I was about to black out the motion indicator (blinking blue light) on my Smart Light 1000 motion sensor outdoor LED and discovered that the plastic white covers on each end were cracked / broken, looks like the sun attacked the plastic. With just a gentle touch both just crumbled in my hand. NOT happy, not considering what they cost and are less than three years old..
I'll report back on their customer service...
I had the same problem on my light, the manufacturer acknowledged that they had used an inferior plastic on those corners, and Sportsmobile Fresno replaced the plastic with what appears to be a much better gauge of plastic. (No charge.)
YelapaPapa is offline   Reply With Quote
Old 01-23-2013, 12:32 PM   #1060
macmcintire's Avatar
The windshield on my SMB cracked in the cold Wyoming weather. My poor Las Vegas baby was not used to this chilly weather.
Mac McIntire
2003 Ford E250, 5.4L V8,
