Originally Posted by rallypanam
Anyone else have an issue with the middle bracket? Not sure how to describe it, but when the awning is hanging on the cleats in the two outside brackets, the middle of the bracket doesn't fit flush with the back of tee middle bracket.. Almost like the awning is sagging in the middle, or the middle bracket is too tall.
Is it just me!
Hi Rally and others!
I am having the exact same issue with the brackets from Van Specialties. The front bracket must go where it must go, on the pillar between the front door and side barn door. I can move the rear bracket around a bunch and the front and rear work great and the awning hangs great with a wide range of positions for the rearward bracket.
The issue is that with the awning hanging from the front and rear, no matter how far forward or rearward I move the rear bracket, the awning hits the Z bend in the middle bracket before the middle bracket is high enough to engage the drip rail. Because the drip rail is not completely parallel to the ground (it is lower on the vehicle near the front and rear than it is in the middle) there is less room between the drip rail and the awning in the middle than there is on the ends. It is as if the middle bracket needs to have the Z bend lower on the bracket to allow for less space between the drip rail and the awning, or have taller front and rear brackets.
It looks like I could mount the front and rearward bracket and mount the middle, but it would not really engage the drip rail. All the real support would be coming from the front and rear only.
I will try and post pics later to help in the explanation.
Is this the nature of the issues with middle brackets that others have had? Most seem to have a problem getting the top of the bracket in the same plane as the front and rears.
