Re: Ford trailer battery charge relay?
rob: Any chance you could put the year, make and model and engine type of your van in your signature. I have the E-Series Wiring Diagram shop manual for the 2002.
You may want to take one of those other relays and put it in the trailer relay terminal and recheck if you have hot at the trailer tow plug.
