One common parasitic draw is the CO detector......not a problem if van sits and you have solar. I think those are about 80ma.
based on boywonder's 80 mA ----> .080 amps,
below is the reality check for the rest of us that think .080 amps is a small draw that can be ignored (spoiler NOT):
Per hour = .080 amps
Per day = 1.92 amps
Per week = 13.44 amps
Per month = 57.66 amps
Add in a few other parasitic and a 100 amp hour AGM is well below 50% in a month with no charging or driving. This is just the wired 12v CO detector.
Add solar (if the van gets sun exposure while parked) or a 3 amp trickle charger to the rig while sitting.
or pull the fuse for the CO sensor circuit while not used!
