Originally Posted by reelchef67
its the one in my sig
2002 e250 5.4
We shouldn't assume everyone has their forum display preferences set exactly the same. When seeking info that's potentially specific to a year make or model including that info in the body of the post---not relying on signatures etc---we get to the solution a bit quicker.
If you have the factory RKE module as Jage says there could be a problem with it. Typically factory wiring tends to stay in place although over time they could loose contact due age alone.
More likely though it the RKE module itself has failed. Some have successfully opened it and effected DIY repairs on the PCB and the surface mounted electronic components---I never have. Another option is finding one already repaired with warranty and exchanging the existing RKE. eBay seems to be a good source for this sort of thing, others here may have personal experience with this as well.
For a "quick fix" I'd look at the master switch block for PW & PDL located on the drivers door---again assuming those too are factory original. Occasionally one of the switch pin sockets will spread apart, the lost contact not allowing the system to work properly. "Bending" those back together SLIGHTLY restores contact and possibly full operation too.
A failed PD switch can also cause this condition but my ideas are its internal to the RKE module.
HTH
