Originally Posted by DerekH
Hi guys, question here. I have an 01 EB 50 with a 5.4L. The van has a 2500 Xantrex inverter. I added a Bosch 2.5 gallon water heater and only plan to use it while the engine is running as to not tax the battery too hard. I have a lifeline agm, 200 AH battery. The setup worked great for a while but I think the battery was on its way out. It is heating less now even with the engine running and the battery dips down to around 10v while the water heater cycles on. I want to replace the battery but don’t want to ruin a new one. Am I correct in thinking that as long as the engine is running the battery should be fine? Kind of confused here.
Thanks
Derek
Derek, You did not list what water heater you are using but if it is similar to this one, it pulls 12Amps at 120VAC. At 80% invertor efficiency that is going to be 120/0.8=150 Amps @12VDC.
As Lilnuts2 has explained, you can do some measurements to confirm what is going on, but for these types of power demands, it is pretty obvious what is likely going on without any further information.
A stock alternator is not going to be able to supply that amount of current at under 3K RPM so you are more than certainly cycling your AGM battery to a low depth of charge and killing its useful life.
Even the 2500 watt invertor cooreponds to a 2500/12/0.8=260 Amp DC demand.
https://www.homedepot.com/p/Bosch-2-...E&gclsrc=aw.ds
I think you are correct in questioning if this is the correct setup. It works for a while but will accelerate the demise of your AGM. A better but more expensive solution is to add a lithium battery for your house battery that is charged from a DC to DC convertor. Without solar or shore power charging this would be pretty straightforward.
People can struggle to even charge a 40 Amp DC to DC for the Lithium because at low RPM it can demand 60 amps DC from the chassis battery. But with lithium, you can colocate the house battery with the invertor and efficiently deliver these types of amps without affecting your chassis battery or alternator.
Given your results with the 200 AmpHr AGM, you might be able to get away with 100 Amp-hr of LifePO because the charge cycles are going to be higher. depending upon what you chose you might be able to do this for $1000 minimum and go up from there.
The other options are an on-demand gas water heater (under $200) or a more traditional gas water heater with a heat exchanger to use coolant to heat the water in addition to gas (probably $500+).
The bottom line is that the 12V electrical current demands for such a setup are very high using conventional lead-acid batteries.
Any type of resistive load for heating is going to be a high demand, and heating water is especially high (e.g. compared to heating air)
