Originally Posted by 1der
Check that harness top to bottom very carefully for rub through and shorting. When SMB makes the cut for the side window they leave very ragged unprotected edges. .
Thanks Ray, I'm aware of the issue, since that's what nearly caused Ramseys van to catchy fire down in Baja. I'll check the harness as best as I can, but it's mostly covered by paneling captured behind the refer cabinet. Never the less, good news.............Suddenly all the lock switches and the alarm remote are working normally, with no repairs from me. I suppose it's possible the batteries were low, since I put a charger on them last night due to the continued actuation of the locks, but I can't say for sure they were low as the volt meter showed a reasonable charge. So, once again the door lock gremlins strike and then depart with no clues as to what they are doing. I can only hope they stay away.
